Need help with Pansat 2700A
Username: Vittu
Post Number: 133
I just got a pansat 2700a original. What file will work and can I still use the same loader to load files to converted FLU. Thanks
Last file loaded on the receiver is 75-2.33_EUbX
Boot ver 75 25th Dec 2007
Username: Nydas
Post Number: 7735
Pansat 2700 - original. Use BL bins and 27.02 loader.
Converted receivers use Blacklist 1.4 loader and CS_ or jvvH_ bins.
If you confuse between these two you may kill you receiver. I have posted this information about 20 times in the last 2 weeks.
Cable for Pansat 2700 is a null cable. Cable for converted receivers is straight cable.
Username: Vittu
Post Number: 136
Thanks Nalin. Got it all right. Just wanted to be sure since it's my 1st Pansat receiver :-)
