New nfusion
Username: Scabz
Knoxville, Tn Us
Post Number: 329
I just got my new nfusion back today. So, what do I need to do first ? The last nfusion I had I installed the newest bin and my receiver died. I want to make sure that this doesn't happen again.
Username: Saqeeb9000
Post Number: 1695
ok
before downloading any thing.. first try to use internet cable and etc and check if there is internet option after u connect internet cable on ur remote...
if u can not see this option after ist step..
go to nfusion forum online.com and download the loader and bin 1.42 ..
then connect internet cable it should work...
Post Number: 1696
and when u are downloading the bin watit 5 minute or so before disconnecting .. let it downlod completly....
Username: Scabz
Knoxville, Tn Us
Post Number: 330
The only thing that I can access is games/system settings/installation. Are you talking about loading the file using the serial cable that came with the nfusion and using the loader to install 1.42 bin ?
Post Number: 1697
so scabz i think what u are saying is that you connect the internet cable to ur reciever before downloading anything and u cannot see internet option on ur reciver... (using ur remote menu ins internet option)...
so this means u need to download the bin first mannullay with serieal cable to install bin 1.42...
after downloading connect the internet cable and u should be good to go...
Username: Scabz
Knoxville, Tn Us
Post Number: 331
Ok, but I thought I have to turn something off first. Emulation or whatever it is .
Post Number: 1699
no.. its after....
once you are all connected..u have latest bin..
then after ...turn off emulator..
Username: Scabz
Knoxville, Tn Us
Post Number: 332
Do I need to unplug everything or just leave it all hooked up when installing new bin ? I usually disconnect everything on my vs platinum and bring it over to my pc.
Post Number: 1700
diconnect everything except powerline ( the cable that go to wall outlet)...
every thing else like input cable from dish antenna and rca cable connected to tv should be removed....
Username: Scabz
Knoxville, Tn Us
Post Number: 333
Ok, it's counting down .
Username: Scabz
Knoxville, Tn Us
Post Number: 335
Ok, it's finished it said update good. So, now can I unplug it ?
Username: Scabz
Knoxville, Tn Us
Post Number: 336
Now I see an internet option. Now what ? thanks
Username: Vndpatel
Post Number: 450
setup you satillite angle
Username: Vndpatel
Post Number: 451
setup your satellite angle, scan channels
Post Number: 1706
scabz how is nfusion working out for you.. let me know..
