BUZZ 2010 (Conversion)
Username: Way2smart
Http://desifta.co.nr/
Post Number: 630
can u convert a Buzz 2010 to some workin receiver or any think else cuz i had that receiver for almost a year the files never come out thx Nalin can u help ,..........
Username: Rtap
FL
Post Number: 1757
the smart 1 the files is here.
http://ftabins.net/showthread.php?t=21561
Username: Way2smart
Post Number: 631
but its Jan 7 file is it working??????? and there are plus and regular i have regular
Username: Rtap
FL
Post Number: 1758
smart1 try it you have nothing to loose
Username: Way2smart
Post Number: 633
fu*ck that its sitting in my room tooo lazy lol!!!!
only if i can convert that receiver its really good receiver but the support is really bad ooo well back to vs ultra
Username: Rtap
FL
Post Number: 1761
DO WHAT I DID I HAD A CLONE 2500 AND USING IT TO BALANCE A TABLE.LMAO
Username: Way2smart
Post Number: 640
hahahahaha
Username: Way2smart
Post Number: 641
i have 2 of them 2500 and still didnt convert them i thought it was going in the garbage when it was kicked out of the pansat family
Username: Rtap
FL
Post Number: 1762
think about unless your a tester why keep the old dinosaur.they are always the last to get support.spend $89 to $180 bucks and get a decent receiver with better support.common sense.
Username: Way2smart
Post Number: 643
i have a cool-sat 7000pvr and vs ultra i am happy with them !!!! i also have 2 pansats 2500 not converted yet and i have 1 megasta and a buzz 2010
Username: Way2smart
Post Number: 644
and forgot to add those card receivers back then the dish network card and the black card
Username: Rtap
FL
Post Number: 1764
how many rooms in your house.lol
Username: Way2smart
Post Number: 649
alot lol
Username: Way2smart
Post Number: 650
i have a dn base lol
