FTA where r u? really need help....
Username: Blueash
Post Number: 40
I am just unable to upload my files to my viewsat extreme box,its been a week now i hav tried every option got new cable new adapter everythng nothng seems to work sometimes i am getting error tht file is sending thn again resending sometimes error is Frame type 00.00.00
Is my box dead or wht?how can i chk tht?i think somethng is wrong wit box port??
really really need help guys....
Username: Abj
Post Number: 510
have you unzip the file?
what loader are you using?
Username: Blueash
Post Number: 41
Loader 2 n yes i did unzip d file
Username: Abj
Post Number: 511
are you sure you have the right type of cable?
if I am not mistaken, I had same problem...
I was using rs232 straight cable instead of null modem cable...
Also, try to load a factiory file from viewsatusa.com
and use loader1 from there also..
I always had problem with loader2
good luck...
Username: Abj
Post Number: 512
sorry, I meant to say use null modem cable not straight cable...
Username: Blueash
Post Number: 42
ok let me try with loader1
Username: Blueash
Post Number: 43
Thankx a lott justice loader1 really helped
Username: Abj
Post Number: 513
glad to help out...
