Pansats BIn - All up
Username: Asharfi
Post Number: 1685
All DN & BEV working ... enjoy Upload
Username: Alftabin
Post Number: 47
BEV working? It says ""GCFIX"
Username: Toney
Antigua
Post Number: 32
Hello AV,
I am not seeing any fix for the Pansat 2700A.
Toney.
Username: Asharfi
Post Number: 1686
Yes, 2 or 3 units are still waiting ... their fix will be out in few minutes
Username: Alftabin
Post Number: 49
hopefully...
Username: Asharfi
Post Number: 1687
Guys,
All PANSAT receivers are working with the bins posted at DSS World. They names might confuse you, but all those bins are new. Ignore the date and that GC ADDED stuff, just simply load and watch television. All bins are tested! Again, you can download the bins from Upload
Username: Alftabin
Post Number: 50
Ok AV, thanks. Will try.
Username: Espn3
Post Number: 214
Please clarify which bins are for genuine Pansats, clone or converted from FLUs. Thanks.
Username: Asharfi
Post Number: 1689
There are no bins for FLU, or clones. All those bins are for genuine receivers.
Username: Nusrat
Post Number: 19
Are the bins also available for Pansat 2500A recievers as well?
Username: Nusrat
Post Number: 20
Username: Nydas
Post Number: 6709
johnson: when the Pansat 2700 BIN is out, I will try and distinguish. At present the Pansat files published are NOT 2700 and NOT 5000 or 6000. The Pansat 9200HD has just been published.
Username: Psychmonster
Rhodium MemberAint nuthin ...
Post Number: 425
get em at the source http://www.future-fta.info/index.php?stage=1
Username: Greenapple
Angeles, Los PHilippines
Nalin is right. just loaded the file as "AV" said, not to be confuse with the dates and names GC fix. Just to confirm to the rest of fta testers, the fix for pansat 2700A is not working for Dick neither for Bev.
Username: Sparky41701
Chavies, Ky Usa
Post Number: 81
is the 234 the newest one out for the 2700A
Username: Lynchmob450
Post Number: 89
234 for 2700A has been out for about a week now. So it is not the newest "fix".
Username: Vsp
Post Number: 208
THERE IS NO FIX FOR PANSAT 2700A AND FEW OTHERS ......YET...........HOPEFULLY IT WILL BE RELEASED TODAY..
Post Number: 426
all pans up except 2700...should be up also within 1 hour.. http://www.future-fta.info/index.php?stage=1
fix for conv should be up later today if BL is still supporting the 2700...only problem and its only a guess is that the 1 MB 2500 may not handle the new encryption Map 057 and timing issues of the super bin, but if this is qa bandaide fix...should be no problem...but we should know by 6 pm tonight est
Post Number: 427
2700 is up
Username: Vsp
Post Number: 210
PANSAT 2700A UP
BIN 235 RELEASED AT http://www.future-fta.info/index.php?stage=1
Post Number: 7
ok all up now for pansat! confirmed at FUTURE FTA site
Username: Asharfi
Post Number: 1693
ALL PANSATS ARE UP NOW ..> FINALLY ...enjoy
Username: Vsp
Post Number: 211
ALL PANSAT RECIVERS ARE UP AS OF 12:59 EST..
Username: Sindhiguy
Post Number: 11
So really what happened to ViewSAT this time ?
Username: Leafs
Post Number: 286
pansat fixes posted at www.ftasolutions .blogspot.com (remove space)
Username: Nydas
Post Number: 6721
All Pansat BINs now available - today's date.
9200HD 1/03/08 dIsH/B3v uP
9000HD 1/03/08 dIsH/B3v uP
6000HXC 1/03/08 dIsH/B3v uP
5000 1/03/08 dIsH/b3v uP
250SM 1/03/08 dIsH/B3v uP
3500SD 1/03/08 dIsH/B3v uP
2800A 1/03/08 dIsH/B3v uP
2700A 1/03/08 dIsH/B3v uP
Username: Nydas
Post Number: 6725
The current 2700 file out is for Pansat 2700 genuine receiver ONLY.
DO NOT USE ON
PANSAT CLONES OR ON CONVERTED 2500-2700
Username: Ash64
Post Number: 55
clone files are released after few hours of releases of original file for pansat 2700.. clone receivers are converted ones.. like pansat 2500, pansat 3000, FLU...dont use future-fta files for 2700 for your clone receivers, it carries clone-kill.. beware..and wait.. (sorry Nalin)
