Anyone having problem with bev / read this
Username: Cartier1
Post Number: 1580
before you updat the keys 0901 turn first your autoroll off , then updat manually the keys . you will get back your bev , but remember to turn on again your autoroll after updating .enjoyyyyyyy
Username: Addtemp
Post Number: 137
I tried entering the Key on VS Pro but No Luck .. Autoroll was on Dish but off on BEv ...
I did Mess Up my BEv 08 01 00 Key by mistake and put the following keys on 08 01 00 but to no avail
BEv 08 01 00
86: 8E 01 FE 27 88 9F 83 CB
C4 AD 85 8C FE 5C 2A 10
96: A7 D5 55 6D 1E B9 3C 9E
57 FA 70 1D EA C2 C5 87
and the Latest keys for BEV 09 01 00
I should mention that by mistake I did overwrite 00 numbers on 9th pair but put 00 back there before saving for 09 01 00 ..Would it effect in any way
Username: Cartier1
Post Number: 1582
u only need to change 0901
as i said turn off the autoroll off off off
insurt the new keys u will have the pic. then go back make the autoroll on .
no i will no affect that /
Username: Addtemp
Post Number: 138
^ yes But I was Wondering that Since I changed my BEV 08 01 00 key It might be causing the issue Now ....
VS Pro don't Allow Op Key Updates so have to do al entries manually.
I will keep checking for any small Mistakes. I think I followed all the steps. Switched of Auto Rool for BEv. Double Checked the BEV 09 01 00 keys. Saved then but still I am getting AutoRoll banner. Even rebooted the Receiver. Will See if I make any progress on that
Username: Cassjum
Post Number: 52
hi I need help can I insert keys manually my receiver is a captiveworks 600 regular pero solo tengo scrambled channel is DN down or is only for me
