Transfer new bin through serial port
Username: Smoke74
Post Number: 37
I was smart enough to buy the vs ultra with a usb port, however my friend didn't. He needs to know how to install the new bin through a serial cable. Any help would be great.
Username: Viruscauser
Leesburg, Georgia
Post Number: 638
What receiver does your friend have?
Username: Smoke74
Post Number: 38
a viewsat ultra without the usb port
Leesburg, Georgia
Post Number: 639
Then he needs a NULL cable, NOT a serial cable.
Username: Smoke74
Post Number: 39
i got the cable that came with receiver...9 pin from receiver to puter
Leesburg, Georgia
Post Number: 640
If it came with the receiver, it's probably the correct cable.
Here is the procedure:
Viewsat 2000 Ultra Setup Guide Using Serial Cable (NULL)/USB
A. Loading your BIN using Null cable:
• Connect serial cable (NULL) to PC>STB
• Open up Loader of choice (PVR-Loader 1.1 or Loader2)
• Click on Tool>Configuration>Com port (Default is com 1)
• Click on Open File
• Click on PC>STB (Notice the progression bar in loader)
• Turn the power in the back ON
• Wait for Loader say Completed. Then on box LCD front panel screen say I.N.S.T>END>0000 or until clock count to 0.001
IT IS VERRY IMPORTANT. DO NOT TURN THE POWER OFF TO SOON
• Turn the power OFF in front and power OFF in back
• After downloading the "BIN", unhook NULL cable from PC>STB
• Connect all the cables to your box/TV
• Turn the power ON in the front and back
• Press Menu key
• Select Installation and press OK
• Select Antenna Setup and press OK
• Select your Sat.
• Here if you have a DISEqC switch enter the port #, Motor or Legacy SW
• No LNB Type need to select (from new, you have only two selection Standard and Universal). STB will select your LNB Automatic
• Press Exit and select Yes for saving the settings
• Your back to Antenna Setup screen
• Here you have Three choices:
1. Channel Scan
2. Auto Scan
3. Blind Scan
• Select Auto Scan
• Press OK
• You are in the Auto Scan window and you see the Bird(Sat.) you selected and on the top of your screen are three options:
1. Search option
2. Network search
3. Scan Start
• You don't change nothing here, go down and select Scan Start and press OK
• You do this for all the Birds (Sat.) you have
• Wait for Autoroll and watch TV
B. Loading your BIN using USB Jump Drive
• Now its time to download your BIN
• Insert the Memory Stick in your PC and transfer the bin in. Then insert in your STB and in the Main Menu select System information and press OK
• Select Receiver Upgrade and press OK
• Go down to the bottom of the window, select USB and press OK
• A new window opens with some Korean files, years, etc.
• In the bottom of the window, it is your bin selects and presses OK
VERY IMPORTANT. DO NOT TURN THE POWER OFF
• Press Menu key
• Select your Sat.
1. Channel Scan
2. Auto Scan
3. Blind Scan
• Select Auto Scan
• Press OK
1. Search option
2. Network search
3. Scan Start
• You don't change nothing, go down and select Scan Start and press OK
By: KidRomeo2
Username: Smoke74
Post Number: 40
thanks...I appreciate it...Happy Holidays
