hi i m useing vs box.i have 3 sat one is 148 and other two are 110 and 119.my diseqc switch is pissed up but not complete its part 1 no more work so i put my 148 sat on port 2 and the other one is on port 3 i use dish 500. but its not work good on 110 and 119 i lost the signalwhen i change the cahnnel and then i shutt off for a second and then i on it then its work.pls help that i stilluse this diseqc or no this diseqc switch came with vs box
Mike I am thinking you may need to change the dish500 lnb's to 2 single lnbs. Then you can use a diseqc switch to contral all 3 lnbs
Or get a DishPro DP34 switch and not use the Diseqc at all. That is the switch DN sells to add a LNB to a dish500 LNB.
Bottom line you can not ever have 2 diseqc switch's inline to a receiver. If you are useing the dish500 LNB it has a diseqc switch built in so you cant use a diseqc switch to add 148.
if i change dish 500 in 2 lnb.then can i use 2 diseqc switch i have an othe switch it same port 1 is not work i want use 2 switch one is form 110 119 and other one gose to for 148 and then i use other switch for 3 sat and one cable go inside for reciver
Dish I would like to invite you to READ my POST. I explained in great detail his 2 options.
Nike,
you can NEVER EVER NEVER use 2 switchs with a FTA receiver the receivewr will not know what switch to control. To control the 3 lnb's you would need only 1 switch. An example would be pos 1 110, pos 2 119, pos 3 148.. Thats if you change the LNB's. I would just go get the DP34 readily avalible at many sites, ebay, or your local radio shack MIGHT have one or a local DN installer...
You can use a diseq 4x1 or a sw 2x1 or a dp34 for 2 recievers. Hook 119 to port 1 110 to port2 and 148 to port 3 on your diseq 4x1.Then in antenna setup change tp freq until you have good q signal then the name of the sat appears. If its a match your good to go.
Semore, Those settings will NOT work if their is a Dish500 LNB connected like this user stated he had. A Dish500 LNB has a switch built in and a FTA receiver can only control ONE switch with the exception of the DP34. You suggested he add another switch.
The question was answered, the user decided to order the correct switch, posted his intention and thanked me. This thread did not need any more information.
Please read the thread, study the answers, look and see if the problem was solved, and then if you have usefull, original( everything you posted was stated in this thread ) educated input feel free to post it.
Tooter sorry buy 119 is port 1 and 110 is port 2,anyway he can get a good used dp34 on e bay for around $25 inc shipping.I had to do that and no problem.good luck
Once again, This thread is over. The settings I posted work with ever dish500 I ever used.
