VS ultra HELP
Username: Ashim786
Can someone please help me?
I put the new bin on totalfta.com onto my vs ultra... however i think that key was for bev not DN... i orginally always have DN...
it was not loading so i pulled out the usb... when it said do not power off... and shut it off...
anyway i can save this now...??> it won't even turn on now... please help...
Username: Saqeeb9000
Post Number: 800
ur reciever is dead now.. how told u to pulled the usb...while it's loading...can u see any light ..any thing when u power on... b.c if u see some light etc.. u will have a chance..
Username: Ashim786
Post Number: 7
when the power is on... there like "----" dash lines on the reciever ... but the image doesnt come onto the tv...
Post Number: 803
ok immediately go to www.totalfta.com
and download factory bin for ur reciever...
Post Number: 804
[link removed]
i think total fta.com is down... go to link above and downlaod it... its safe to download..
Username: Ashim786
Post Number: 9
how do i get it to load onto the reciever if i can't go into the menu option...?
Post Number: 806
u don't have a cable to download .. from pc to ur reciever.. like a null cable..
i know viewsat ultra comes with usb.. but i think (if it comes with cable ). u can plug in the back...of ur rec...
Post Number: 808
posted by ashimm
""put the new bin on totalfta.com onto my vs ultra... however i think that key was for bev not DN... i orginally always have DN... ""
it doesn't matter.. next time let usb to finsish its job...
Username: Merk
Post Number: 13
it will reboot if you turn it off and then on with switch on back but dont do it yet i would wait and keep getting info to be on the safe side i have never had this prob so i dont know what will happen when it reboots.
Username: Ashim786
Post Number: 10
can i just plug in my usb into the reciever ..and it will read it automatically ..w/o me going to menu and uploading it... ?
Post Number: 809
yesterday there was guy with similar problem.. after downloading factory bin... it worked fine for him....
Username: Ashim786
Post Number: 11
mjhp....
kinda late for that.. i already turned off the reciever... and took out the usb... so that's why i thought i was screwed...
Username: Merk
Post Number: 14
i dont think it will do it like that just wait awhile for more info. but if it reboots when you turn it off and on you will have the the picture back on your tv screen just dont be in a hurry and like sada said wait and get the factory bin to put in it if it does reboot
Username: Ashim786
Post Number: 12
thank you so much for ur help sada... i will try and see if this works... i dwn loaded the factory bin...
Username: Merk
Post Number: 15
did you do it from the back switch?
Username: Ashim786
Post Number: 13
yesh i did... i turned it off... already... should i put the usb back in... caz it won't turn on... like i dont see anything on the screen when i try to turn it on... just the dashes on the reciever...
Username: Merk
Post Number: 16
yes it wont hurt anything now cross your fingers
Username: Ashim786
Post Number: 14
okay so the reciever doesnt even turn on now... wat can i do?.... anything...???
Username: Merk
Post Number: 17
if you have no dashes its dead but if there are dashes theres hope go and look at old post from yesterday and day before there was some one that got theres working and how they did it is in those post good luck
Username: Oleg1474
Florida Usa
Post Number: 634
well something this good shouldn't die
pouring over this all evening.
as with the ird to fta work lately to me its the last area of the hobby I need to play with
I am finding the hobby really boring, its never about tv its about doing something new and learning.
and would love to work on the Viewsat & Pansat. for just shits and giggles.
when satfta left/was made to leave the hobby it left a rather large hole, then cc closed. so much is done closed source now. I don't think the advent of the fta has detremented the hobby I just think it hasn't been used to its full potentional. a box we can mess with and the legal providers can NOT write legally. so its only our code to deal with no updates. just wish more was done open source and publically exploiting the hardware having fun.
even the crappiest fta has a cpu and ram that far outruns a echostar Euro/ECM666
I don't own an fta so plan to mess with the echostar Euro/Ecm66 just as a winter play project it probably won't amount to much but atleast have fun trying.
now for an utter NEWBIE question
in page 2 of this thread
to quote O-PHD-2
Quote:
0x7FFFFFFE, the top of memory (because it is signed addressing) , the last few bytes of the Flash (or TSOP for those who didn't know). At that location there will be a jmp to some address close by (as it only allows for 2 bytes). This is common to see amongst all versions.
loc_7FFFFFE7:
7FFFFFE7 272F2F2F20202040 ldc #7FFF0000
7FFFFFEF F6 gcall
7FFFFFFE 6107 j loc_7FFFFFE7
Or something along that lines (as the board will really mess up my formatting).
now shockingly in the E666 bev Euro/Ecm666 tsop I have
Code:
7FFFFFFE 6107this using 7FF80000 as a base offset in hex workshop
now using these to documents
View/C4 Core Instruction Set Reference Manual pdf
View datasheet pdf
I don't see where the j routine is broken down from the 61 or 07 I am and I know this is a bad thing but ASSUMING the 61 is the jump and the 07 is its relative addressing
page 95 of the first pdf
Quote:
j n jump
Code: Function 0
Description: Unconditional relative jump. The destination of the jump is expressed as
a byte offset from the first byte after the current instruction. j 0 causes a breakpoint.
Definition:
if (n = 0)
Take a breakpoint trap
else
Iptr4 u next instruction + n
Areg4 u undefined
Breg4 u undefined
Creg4 u undefined
Error signals: j 0 can cause a breakpoint trap to be signalled.
Comments:
Primary instruction.
Instruction is a descheduling point.
Instruction is a timeslicing point.
so I understand its a primary instruction
now by the View pdf
Code:
Function
code Memory Mnemonic Processor Name Notes
code cycles
0 0X j 5 jump D,Tnow
Quote:
Notes
D Instruction can deschedule
T Instruction can timeslice
I am just trying to understand the nomenclature
am familar with asm and its one of my favourite languages
and have worked on the mostek the intel and motorola processors
and I figure no point going past the first instruction until I understand it. so I probably need to be hit with a clue x 4.
but any takers or pointers?
and yes my 7FFFFFE7 exactly matches what Dave2 posted but I figure as I stated above might as well start off on the right foot.
I love the winter gives time late nights for reading the old threads.
Thank you!! Oleg PHD@usa
oleg
Username: Oleg1474
Florida
usa
Post Number: 630
Posted on Sunday, December 16, 2007 - 12:32 am:
well still up reading so might as well correct myself on my wrong assumptions
not sure what this dump was from but the relevant code matched and was dissassembled
Code:
e509| from loader.txt found in the sti5518 development on curious contraptions
20 | 7FFFFFE4 20 PFIX 00000000
20 | 7FFFFFE5 20 PFIX 00000000
20 | 7FFFFFE6 20 PFIX 00000000
27 | 7FFFFFE7 27 PFIX 00000007
2F | 7FFFFFE8 2F PFIX 0000007F
2F | 7FFFFFE9 2F PFIX 000007FF
2F | 7FFFFFEA 2F PFIX 00007FFF
20 | 7FFFFFEB 29 PFIX 0007FFF9
20 | 7FFFFFEC 22 PFIX 007FFF92
20 | 7FFFFFED 22 PFIX 07FFF922
40 | 7FFFFFEE 44 LDC 7FFF9224
F6 | 7FFFFFEF F6 GCALL_0006
F4 | 7FFFFFF0 80 ADC 00000000
F1 | 7FFFFFF1 E0 STNL 00000000
FF | 7FFFFFF2 FF OUTWORD_000F
7F | 7FFFFFF3 7F LDL 0000000F
A0 | 7FFFFFF4 A4 CJ 00000004 (7FFFFFF9)
F1 | 7FFFFFF5 DD STL 0000000D
FF | 7FFFFFF6 FF OUTWORD_000F
7F | 7FFFFFF7 7F LDL 0000000F
01 | 7FFFFFF8 00 J 00000000 (7FFFFFF9)
00 | 7FFFFFF9 02 J 00000002 (7FFFFFFC)
00 | 7FFFFFFA 00 J 00000000 (7FFFFFFB)
00 | 7FFFFFFB 80 ADC 00000000
20 | 7FFFFFFC 20 PFIX 00000000
20 | 7FFFFFFD 20 PFIX 00000000
61 | 7FFFFFFE 61 NFIX FFFFFFFE
07 | 7FFFFFFF 07 J FFFFFFE7 (7FFFFFE7)any hints truely appreciated so is it working in nibbles or bytes. just talking to myself laugh. will keep reading in the morning, anyway thought I'd post to keep the thread alive.
the 0 at 7FFFFFFF 07 I understand the 7 puzzles me but more when I wake.
Thanks...
Username: Ashim786
Post Number: 17
Oleg....
I have no clue wat ur talking bout ...but i'm very sure it has nothing to do w/ the question i asked... Please keep ur random thought in another thread.. thanks...
Username: Rohinivikas
Post Number: 18
ashi,
can i have your email address? Did you find anything?
Username: Ashim786
Post Number: 19
i haven't found anything but my e-mail is ashim786@hotmail.com.... if u do find anything... plz let me know... thanks
Username: Gspot6977
Seattle, Wa Usa
Post Number: 17
I will try to send U the file U need...U must load it from your pc to box via cable. Do you have the viewsat loader2 ? Use that to load. I had the same problem yesterday and its up and running now
Post Number: 23
My email is v_nanda70 and it is an hotmail account. I have 2 laoders. One is Loader 1.1 and other is Loader 2. I think in need to first upload Boot file which is .hex file and then factory bin. Am i making any sense. When you send me some files, could you also please send me clear instructions how to put the file into the box because i tried yesterday with loader and the progress bar did not move at all
Username: Ashim786
Post Number: 20
thank you so much for ur help kevin....
i dont have a loader... i'm new at this ...very lost bout wat to do... any help would be great... thanks again...
Username: Gspot6977
Seattle, Wa Usa
Post Number: 18
ashi m
I used loader2 . . load your file into the loader.(VSU FAIL FIX) .have your ultra off...when you press the write to button on the loader and the window pops up on your pc screen turn your ultra on using the switch on the back..... it should start loading and when its done your display will be back. I had to rescan the channels on mine but it is working fine now.. my old bin was still intact.
Sent loader and fix to your email gspot
Username: Ashim786
Post Number: 21
Kevin....
thanks so much ... i will try this and let u know if it works...
