Pansat 2500 converted 2700 channel list?
Username: Snw7619
Bahamas
Post Number: 98
im haveing trouble find the correct channel list for my pansat 2500 converted to 2700...please send info help..
i deteted sat echo 110 and echo 119 and then blind scaned to get them back but im missing some of my favorite channels such as ESPN and SunSports and Disney for the kids.
Username: Snw7619
Bahamas
Post Number: 99
thank you in advance...........
Username: Viruscauser
Leesburg, Georgia
Post Number: 517
Does this help?
unknown/unknownUpload
11_18_Full Scan_Pansat.rar (19.6 k)
Username: Snw7619
Bahamas
Post Number: 100
is that the channel list for pansat 2500>2700?
Leesburg, Georgia
Post Number: 518
yes. Write it to your 2500>2700 as a 2700 list using channel master.
Username: Snw7619
Bahamas
Post Number: 101
ok how do i get channel master
ive downloaded blacklist uploader im new and really lost........
Username: Snw7619
Bahamas
Post Number: 102
abby??help me please
Leesburg, Georgia
Post Number: 520
you don't use the BL lader to load this!!!!!
Username: Snw7619
Bahamas
Post Number: 103
will how do i find that file
Username: Snw7619
Bahamas
Post Number: 104
Channel Master V-cmsetup1_16_05_3.zip
i found this only!
Leesburg, Georgia
Post Number: 521
get channel master for free from SharpC. Connect your comp to your receiver, run channel master on your comp, open this list in CM after extraction from compressed state, go to Tools>write to STB>choose Pansat 2700 in the dropdown menu and write it to your std.
After it's written successfully, the STB will reboot on it's own.
Username: Snw7619
Bahamas
Post Number: 105
i found this is this correct?
Leesburg, Georgia
Post Number: 522
Current CM version is 1.18.4. SharpC. Google it.
Username: Snw7619
Bahamas
Post Number: 106
cmsetup1_18_04.zip
is this the right one here?
Username: Snw7619
Bahamas
Post Number: 107
for my pansat 2500 converted to 2700 which channel list should i use 2500a or 2700a?
Leesburg, Georgia
Post Number: 523
LOL. Are you really reading all I'm writing?
Username: Snw7619
Bahamas
Post Number: 108
i know ive got it downloaded now which one should i upload to reciever 2500 or 2700?
Username: Jack_meoff
Post Number: 64
Well... you converted it to a 2700, didn't you?
Username: Snw7619
Bahamas
Post Number: 109
well thanks Mr. jack-off
Leesburg, Georgia
Post Number: 524
Abby
Leesburg , Georgia
Post Number: 521
Posted on Tuesday, December 11, 2007 - 08:48 pm:
What do YOU think?
Username: Snw7619
Bahamas
Post Number: 110
lol ok flabby thank alot though
Username: Snw7619
Bahamas
Post Number: 111
Post Number: 66
Wet us know if we were wight or wong.....
Leesburg, Georgia
Post Number: 528
Username: Snw7619
Bahamas
Post Number: 112
well family watching sat now so ill have to try it later or tommorrow
Username: Snw7619
Bahamas
Post Number: 113
after i update channel list then do i have to re-programm sat also?
Post Number: 68
You'll get it. Just take your time and all will be well.
Username: Snw7619
Bahamas
Post Number: 114
is that a yes?
Post Number: 70
You might have to set your switch port setting. The channel list's settings may or may not match up with your current set up.
Leesburg, Georgia
Post Number: 530
You might have to change the LNB from DishPro to Standard, mabe, but that should be about it.
Set Default Keys and see if the keys roll. Can take a long time for the first keys to be obtained so be patient.
Username: Snw7619
Bahamas
Post Number: 115
it say downloaded completed with errors
commnacation errorrs???
Username: Snw7619
Bahamas
Post Number: 116
it wont download it from CM to pansat?
Username: Snw7619
Bahamas
Post Number: 118
help
Username: Asharfi
Post Number: 1590
shannon wong,
I saw you asking the same question at DSS World. Look, it's very simple and easy. Go to www.dssworld.co.nr and download the following files:
- Channel Master from FTA Receiver Guides forum
- Black Tyger Channel List 2 from the same forum
Then, open the channel list in Channel Master. Make sure your receiver is connected to your PC and make it's ON. Then, on Channel Master's window, click on TOOLS, and then click on Write To STB. Select model name Pansat 2700 (i know that u hv converted unit), but I still want you to select model name Pansat 2700. Then, click OK and check the COM port ... after that click ok and the download will start
Username: Snw7619
Bahamas
Post Number: 119
AV ive done this many time it keeps say downloaded with error, communacation errors and never starts the download process of channel list when i select write to reciever im selecting com 1 also
Username: Snw7619
Bahamas
Post Number: 120
http://www.sharpc.com/forums/default.aspx?g=cm_projectlist
this is where im getting Channel list form using
2500 to 2700 mod list uploaded from box after blindscan.cmproj
