Bronze Member Username: JerkislandPost Number: 29 Registered: Mar-07 | When I did a Blind scan or a Sat scan one of the channels I wanted didn't show up. Is there a way to manually add the channel in ? Please let me know. Channel Info Network: UDAYA TV Satellite: 118.7 Category: INTERNATIONAL |
Bronze Member Username: JerkislandPost Number: 30 Registered: Mar-07 | I am trying to add the channel on Viewsat Xtreme |
Silver Member Username: Saqeeb9000Post Number: 641 Registered: Oct-07 | yes u can do an advance scan.. just put freq,pol etc for channel and then u will get it... www.lyg*sat.com for freq...etc.. |
Bronze Member Username: PrincePost Number: 57 Registered: Jun-06 | Hi sada - could u help my out with flu 2700 receiver. |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1809 Registered: Sep-06 | king stop hijacking threads |
Silver Member Username: Saqeeb9000Post Number: 643 Registered: Oct-07 | king what kind of help u need? |
Bronze Member Username: PrincePost Number: 59 Registered: Jun-06 | Can someone please help me with the Antenna setup for FLU 2700 |
Silver Member Username: Saqeeb9000Post Number: 644 Registered: Oct-07 | how many dishes u have? and on which direction? |
Bronze Member Username: PrincePost Number: 60 Registered: Jun-06 | I am trying to get Echo star3 61.5 & Echo star 7 119.0. |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1811 Registered: Sep-06 | let them go start a new thread please it is not fair to the user who started this one for it to get all confused with a Antenna pointing question. |
Silver Member Username: Saqeeb9000Post Number: 645 Registered: Oct-07 | so dishes are already installed outside i believe.. go on ur remote menu,settin and change the port setting... and then change the dishes name lets say 61.5 (it either will be in port 1 or port 2 ).. change the ports to 1 it will show you green signal on bottom and dish name on top..and then press ok and scan the channels... |
Silver Member Username: Saqeeb9000Post Number: 646 Registered: Oct-07 | sorry fta tester...next time i need to type faster.. *------------- |
Bronze Member Username: PrincePost Number: 61 Registered: Jun-06 | I totally understand Tester therfore I started a new thread @ https://www.ecoustics.com/electronics/forum/home-video/413396.html |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1812 Registered: Sep-06 | Good job King I will meet you their. |
