Fortec ultra dead
Username: Serj5150
i had put the new file in my receiver and it worked for about 2 hours now it is completely dead.If anyone could help me it would be greatly appreciated
Username: Nydas
Post Number: 5636
What was th econversion status? what file did you put in.
Is there ANY light anywhere when you switch on - if not, check fuse inside and the you will need to jtag if fuse is OK.
You can jtag to original or or you can jtag and install the latest 225 BIN using CS_225T_FS-LifeTime-Ultra - Flash 1(29LV800BTC) - JTAG.bin
Username: Serj5150
where would the fuse be located?
Username: Serj5150
x-87bl_071202_b75_225_api this is the file i used
Username: Asharfi
Post Number: 1556
Usually, the fuse is located somewhere near the power cord wire and yes, you have to open your unit to install the fuse. Near that power circut, there will be small black box. Open that and you'll see a glass tube which is the fuse. Take that OFF, just like you take a battery off a remote. Then, intall the new fuse.
Username: Asharfi
Post Number: 1557
BTW, the file that you used (x-87bl_071202_b75_225_api) is NOT for FLU units. Looks like your FTA unit fuse is okay ... just have to JTAG
Username: Serj5150
Post Number: 7
my ultra is converted to a pansat 2700
Username: Serj5150
Post Number: 8
i'm still trying to find the fuse
Username: Serj5150
Post Number: 9
man i just can't find it
Username: Serj5150
Post Number: 10
thanks for the help any ways guys but i'm going to bed
