Viewsat ultra
Username: Bbford
which loader do i use for viewsat ultra thank you.
Username: Psanand
Oakville, On Cananda
Post Number: 23
check totalfta.com
Username: Hshakarchi
Post Number: 148
if you have ultra why dont you use the USB stick to load your Bin
Username: Dude123
Post Number: 1404
good point hanibal!
All you have to do is tranfer the file in the usb that it came with using your computer and then transfer it from the usb to the receiver!
Username: Rtap
FL
Post Number: 1264
bob follow this link there u will find the loader u need.remember as stated from hanibal and the one it is easier to load by usb.
http://ftabins.net/showthread.php?t=1096
Username: Bbford
Post Number: 7
Its not my box its a freind and he does not have the stick yet and as i am not that farmilar with it i did not want to talk any chances thanks for the advice.
Username: Buddho81
Post Number: 45
with the usb drive you're not taking a chance...Its actually the easiest way to load a file onto an Viewsat Ultra!
I have been using it for past 6months and I have never connected this to a computer!
Good luck!
