Viewsat platinum lite DBPSW 071124p
Username: Satgrl
Post Number: 702
is this is working bin for viewsat platinum? is there any problems with it? i got this frmo dsscentral?
Username: Chicky3884
Post Number: 127
satgrl where can i find a factort reset bin?
Username: Rtap
FL
Post Number: 1161
chicky there is no factory reset bin.
1.go to menu
2.look down the list to factory reset.
3.code is 0000
4.load the factory bin available at futureftadotinfo or ftabinsdotnet.
5.then load the most current bin 339. scan your satillites and watch tv.
Post Number: 129
I did that ,but it still freezes and goes to scrambled/bad channel,and after I have to change the channel and turn power off and on to get it back on. Could it be the bin from futurefta? Should I try the other site?
Username: Rtap
FL
Post Number: 1165
whats your signal level and quality.do you have any switches.
Username: Satgrl
Post Number: 703
umm anyone answer my question...:-(
Username: Rtap
FL
Post Number: 1167
satgrl get your files from totalftadotcom.the home site for viewsat.the most current file is.
DBPSW-071124P-2.zip
Username: Satgrl
Post Number: 704
ok thanks RTAP what about sonicview the newest bin is 177p? is that working?
Username: Satgrl
Post Number: 705
oh and what is SvSoftkey 2.03 ...and what does it do?
Username: Rtap
FL
Post Number: 1169
satgrl this is what i read about sonicview 4000.
Hello everyone,
Here is SV4000_V0177P micro blackout FIXED for SONICVIEW SV-4000.
enjoy,
SV4000_V0177P
*** Micro blackout *FIXED*
NOTE:
- Do a hard reboot (power OFF-ON using rear switch) after every update.
EnJoy!
Username: Satgrl
Post Number: 706
ok thanks RTAP...umm what is micro blackout..im confused..lol
Username: Rtap
FL
Post Number: 1171
maybe fixed a freezing problem causing your screen to blackout.
Username: Satgrl
Post Number: 707
oh yes yes..ok wish me luck im going to load the new bin in my sonicview 4000(SV4000_V0177P) and my friends viewsat platinum...(DBPSW 071124p)
Username: Rtap
FL
Post Number: 1172
don't forget to watch the free p0rn.lmao just kidding.
Username: Satgrl
Post Number: 708
..lol..no thnxs
Username: Rtap
FL
Post Number: 1174
what do you mean no thnxs.what girl now a days don't watch p0rno.are u married cause even married people watch p0rn.lol
