HELP WITH 118 PLEASE
Username: Davidof
Post Number: 7
CAN SOMEONE PLEASE TELL ME HOW TO CATCH 118 PLEAESE?
I HAVE 110 & 119 THANKS
Username: Space_invader
Andromeda M31
Post Number: 240
It is easy... You need a double freq. LNBF... It is like this one:
http://cgi.ebay.com/ROC-CIRCULAR-DUAL-LNB-LNBF-CB2008A-119-118-7-DISH-118-8_W0QQ itemZ150187582704QQihZ005QQcategoryZ149971QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Then you install this LNB to your 119W dish and you can get 119 & 118 with your Box. Just configure somethings in the setup menu and you're done!...
Username: Ke5aqn
Post Number: 910
Anyone have a transponder list for 118?
Thanks
Username: Frobi
Guelph, Ontario Canada
Post Number: 90
What is the difference between 118 and 119? Also what different channels each provide?
Username: Runnerguy
Pluto
Post Number: 801
http://www.lyngsat*com/anikf3.html
Username: Nydas
Post Number: 5254
You can buys a 119/118.7 LNB for about $20-$25. Do a google and you will find several adverised. You need a 30" dish and that might be a deterrant to some.
Username: Asharfi
Post Number: 1483
I think you can use the 110-119 dish to receive the 118 channel ... all of have to do is attach another LNB
Username: Ke5aqn
Post Number: 911
Ok heres the deal
118 is a KU sat and 119 is circular so you have to have a LNB that can get both....thanks to Zulu for providing the link to the lynsat page it was helpfull.....and yes Nalin their are several
2 Sats In 1 Ku Band DSS Circular Dual LNB for 119/118.7 on eb ay and other places....
