2500 pansat gone need some help
Username: Goldy
Ok so my pansat2500 is totaly gone and i am looking at othere boxes to buy. Any suggestions between c**lsat, viewsat etc. and also there was a forum for newbies that helped you set up your box and i cant find it now any suggestions on that as well.
Thanks
Username: Rtap
FL
Post Number: 1092
go with the viewsat,sonicview.a lot of people are saying conaxsat but i never personal experience.
Username: Sydfahim
Post Number: 14
AV, Lk, Nadin
I tried to down load b75 to convert my pansat 2500
to 2700 but it gives me nightrider would you help me
Thanks
Username: Nydas
Post Number: 5037
syd: Go to
https://www.ecoustics.com/electronics/forum/home-video/402679.html
Look at the first post, and follow the detailed instructions. The only change would be that you should install CS_222T_lightning or CS_223T_Lightning, instead of the UKR BIN
Those instructions, when followed properly, do work. If they do not work for you, then tough luck.
