How to Fix C00lsat receiver...
Username: Space_invader
Andromeda M31
Post Number: 79
"How to bring your CS 5000 or 6000 box back to life ..Hook up your box to your computer using the correct straight through cable, then open proloader 2.4 and browse to the Factory bin.. (CS5000_100_20051007).
Now hit auto detect, your pro loader will ask that you "connect your receiver and turn it on" now turn on the rear switch on your CS and click "connect" proloader will repeat "connect your receiver and turn it on" now turn off rear switch and then turn on..now it should start to load the factory flash. you may have to turn off switch then turn on while clicking connect at the same time for this to work., repeat as necessary until it takes the file."
By Hylo
"Once it has taken the flash, hook up to your T.V and go to menu-system system settings-database reset and do a factory set. Now hook up once again to your P.C and load a fresh copy of the new bin file."
by Hylo
