222 bin
Username: Sparky41701
Chavies, Ky Usa
Post Number: 42
does any one know if the 222 bin is for the pansat 2700 A thanks}
Username: Viruscauser
Leesburg, Georgia
Post Number: 393
It's for the Genuine Pansat 2700A/E. If you have a clone, wait for the clone-safe version. If you have the Genuine Pansat 2700, get it while it's hot!!!
Chavies, Ky Usa
Post Number: 43
thaks abby i have a pansat 2700A its on dsstester just didnt say what its for thanks again
Chavies, Ky Usa
Post Number: 44
Just downloaded it works great so far
Username: Angelo921
Post Number: 57
has anyone tested bin 222 for DN to see if it causes the same problems as bin 221?
Username: Angelo921
Post Number: 58
Where did you guys get bin 222 from? I got it from http://www.future-fta.info/Forums/forumdisplay.php?f=43 but it will not open in GTRom Loader. It gives me error unknown file type error.
Username: Lklives
Post Number: 13636
unzip the file first...
Username: Alex35
Post Number: 99
Im tested and bin 222 have the same problem! Re-boot!!!!!!!!!!!!
Leesburg, Georgia
Post Number: 402
Yup. Reported to have the same reboot problem. Some suggest other minor modifications were made, maybe to do with Bev autorolls, but the reboot problem remains.
Username: Letmeon
Post Number: 156
reboot problem - try turning A/R off.
221 ver 2 for 2500 to 2700 converted working fine. quick channel change, PPV on. A/R good
Username: Poonam008
Post Number: 15
Can anyone please provide bin file for Fortec Lifetime Classic NA?
Username: Nydas
Post Number: 4909
Poonam : You are highjacking this thread.
Fortec Lifetime Classic NA is D E A D - No more files, E V E R!
Username: Poonam008
Post Number: 20
I didn't know but I have strated new thread.
Username: Lolol
Post Number: 151
what was bin222 suppose to fix anyways? rebooting issue??
Username: Nydas
Post Number: 4915
lolol: Initial reports are not very encouraging.
