Bruce I . Do i need to reload the factory Bin Captive Works 600s
Username: Book77
Post Number: 86
As I said in my last thread. I have CW 600S and since I loaded the last bin 1.39 it will not comunicate to my computer.
I am using loader 1.05
Do in need to load the factory bin and start over.
Where do i get the factory bin.
Help
www.www.ecoustics.com/electronics/forum/home-video/396602.html
Username: Brucester
Post Number: 574
CW-600S: Factory Bin (1.14) 02/20/07
Factory bin.
Looker
Attached Files CW600SV1.14_Recorder_2_20_07.zip (791.
i got this from dssrookie*com chang the *to a dot. it is free to reg you will get your box going if you go to this site
Username: Frobi
Guelph, Ontario Canada
Post Number: 66
Bruce, what is the latest file for CW 600s premium? I downloaded CW600PV1.53 yesterday (24/10/07) but most channels were scrambled. Echo 3 and PPV were not coming. Only some were working.
Thanks again.
Username: Brucester
Post Number: 576
im on bev all is good im using bin 152 but went on dssrookie and lots of others are having trouble you can try doing this factory reset then enable patch and when it rolls turn off auto roll this might help others are reporting that it started working after a couple of hours and others say it is working good if i were you i would go to dssrookie*com change*to a dot. and read what others are doing or wait till tommorow and there will be a nother bin to fix this one.
