Username: Satgrl Post Number: 93 Registered: Oct-07
Thursday, October 25, 2007 - 13:49 GMT is the pansat 2700A (original) bin out yet the one with the new PID fix? and does it have to be b-75 upgraded in order to load this new "bin"
Username: Satgrl Post Number: 94 Registered: Oct-07
Thursday, October 25, 2007 - 13:55 GMT anybody?
Username: Satgrl Post Number: 97 Registered: Oct-07
Thursday, October 25, 2007 - 14:04 GMT is this the right bin from ftabins*net????????????????????????????????? greeny Super Moderator Join Date: Oct 2006 Location: Umm, the Green of Greenland of course. Posts: 1,617 Rep Points: 51 X-87BL_071023_B75_218_api_1.zip -------------------------------------------------------------------------------- X-87BL_071023_B75_218_api_1.zip newest 2700 fix. (TBL version 218)X-87BL_071023_B75_218 Dish/Bev Bug Fixed
Username: Satgrl Post Number: 100 Registered: Oct-07
Thursday, October 25, 2007 - 14:12 GMT is everybody dead please help its ergent!
Username: Skypatel Post Number: 55 Registered: May-06
Thursday, October 25, 2007 - 17:17 GMT yes it is correct. use X-87BL_071023_B75_218_api_1.zip bin
Username: Satgrl Post Number: 146 Registered: Oct-07
Thursday, October 25, 2007 - 17:41 GMT thank u ...which loader should i use?
Username: Satgrl Post Number: 148 Registered: Oct-07
Thursday, October 25, 2007 - 17:56 GMT sky patel i treid this i get night rider lights thingy what should i do now?
Username: Jimmrr Post Number: 9 Registered: Jun-06
Thursday, October 25, 2007 - 18:21 GMT Hi guys, one question, how can I access a satellite which was accidentally deleted from the selection. Example nimiq 2 was accidentally delete from my receiver table, how can I bring it back. Please guys, its a matter of life and death. Thanks
Username: Fahq Post Number: 6 Registered: Jul-06
Thursday, October 25, 2007 - 18:54 GMT satgrl-you need to learn how to f**kin relax!
Username: Donnie1973 Post Number: 1354 Registered: May-06
Thursday, October 25, 2007 - 18:56 GMT Just go to installation- antenna set up - select ur sat- scan it.
Username: Fahq Post Number: 7 Registered: Jul-06
Thursday, October 25, 2007 - 18:56 GMT Jimmy, go to lyngsat . com and get one to the TP's for Nim2 then go into the "edit satellite" menu (WOULD BE NICE IF I KNEW WHAT STB YOU HAD) and then just add that bird with the TP info and scan
Username: Jimmrr Post Number: 10 Registered: Jun-06
Thursday, October 25, 2007 - 19:00 GMT thank you very much roger....dante....more power guys
