Bug report on new Viewsat Ultra bin file...
Username: Hanz
Post Number: 375
The following channels are missing from bev after uploading the new bin file for the Viewsat Ultra, released yesterday Sept 10.
*LfsTV(leafs tv) channel 2387
*GolSP (Soccer channel) channel 2388
*WLDTV (Wild) channel 2389
*FIGHT (Fight Network) channel 2390
Constant 'autoroll processing' for these channels to no end. All else seems to work fine for both dish and bev.
Username: Hanz
Post Number: 376
Sorry, what I meant to say was that these channels are 'autorolling'. They are NOT missing from the actual channel lineup. My bad.
Username: Bowshocker
Thanks. What do we do if some channels are missing
also 091107 pgm file is not working. It is read and rebooted but receiver information still says it has 090507 pgm.
Missing some channels in 12297 freq
i.e not appearing at all in channel guide after any number of deletions and re-scans.?
All other frequencies come at 80% sig 70% quality
Username: Hawaiian_time
Kanaka freak...
Post Number: 1429
Try flashing your ultra with the factory bin first then the newest one.
Post Number: 7
tried with v119 then v124 then 0901107 pgm..
Reading the file...
(very quick no increment bar which comes normally)
Caution: do not power off (this did not come)
automatic reboot pointing pgm as 090507 not the new one !
Also tried to use channel scan and "add user channel" aid vid pid defaulted to 8192 and never allows to edit
Username: Dghumman
Ontario Canada
Post Number: 111
did u unzip the files if thats the reason then u will still have the old file
Kanaka freak...
Post Number: 1430
If you are using the a USB stick, make sure you select USB in the upgrade menu.
Post Number: 11
Thanks guys
yes i unzipped the file 1.509 kb and used usb upgrade..it is reading the file and rebooting but shows up info as 090507
is it showing the new info for you in receiver information i.e. 091107
