SONIEVIEW
Username: Vsp
Post Number: 138
hi guys
i have a sonicview SV4000 and someone please post a tutorial on how to manually enter keys and if there is any new bin released please post the link
thank you in advance
Username: Lklives
Post Number: 11889
To Manually enter SonicView Keys
Menu > Entertainment Tab > Enter 7890 and "Code" will appear > Choose Nagravision for CAs and then choose Dish or Bev on the line under CAS
*Notice the two sections for Dish, being 0001 and 0101 - 0101 is the one you want to edit
-The bottom 4 lines for Dish are the ones you want to edit.
*Notice the two sections for Bev, being 0801 and 0901 - 0901 is the one you want to edit for Bev..
1) Press MENU
2) Go to ENTERTAINMENT category and press 7890
3) A CODE option will appear, press OK
4) Press the down arrow and make sure the category is on DISH <01>
5) Highlight line number "20" then press the right arrow and start entering the first 8 numbers of the active key
6) Highlight line number "21" then press the right arrow and start entering the second 8 numbers of the active key
7) Press EXIT - Click "OK" on "YES" to save the changes
8) Go into SYSTEM SETTINGS - USER OPTIONS and turn Autoroll to "OFF"
9) EXIT out of everything and wait 30 seconds, your tv should be back on.
Note: Row 10,11 are for Key 00 and 20 and 21 are for key 01
The new SV 4000 bin is at www.totalfta.com front page!
BTW...U don't need to manual enter the keys with this new AUTOROLL bin....set it and forget it!
Username: Vsp
Post Number: 143
thans
man where do u get all this info?
thnks once again
Username: Dude123
Post Number: 1159
V,
LK is a Platinum member of this site, he has alot of info about every receiver every satellite and providers and we all respect that (well atleast some of us respect that) and not only that he is a mod on dss sites aswell. And all the information is available on all the sites. you can visit any of the following sites the list has been created by LK and posted alot on this site. You can find how to guides bin file loaders and bug problems with bin files and alot of other usefull information you just have to read and learn so I am posting the list of site again that has been created and posted by LK.
LK
Username: Lklives
Post Number: 11885
Posted on Tuesday, September 11, 2007 - 08:02 pm:
All these sites ALWAYS have the latest files, bins, how to's, manuals, guides, dish pointing calulators and tips, hardware info, jtag info, newbie and getting started sections, actively moderated with a no troublemakers and no bashing allowed policy.. and are free, and only require a simple free registration...Your email info is kept private, unless U specify differently..and U will be notified via email of any replies to any questions U may ask (or U can shut that feature off, if U like)..and your IP is sacred and never released..
Many of these specialize in particular FTA receivers as noted next to their links..USE those for your particular receiver manufacturer..
If U want real info, trouble free, no costs, friendly help, no hassles, latest files and manuals, then use these...these are well established, and have a long history, and are the best known sites throughout the entire DSS community now...
Ecoustics is NOT a Dss site, since is has NO files, no manuals, no guides, little info, no specific categories, and is almost impossible to find anything because every thread here has been allowed to be hijacked (because no mods are active) and the Subject does not relate to the posts within it....also Ecoustics is basically an Electronics site for home audio, television, DVDs, stereo's, and things of that nature, NOT FTA satellite information .
So again I highly recommend using ANY of these sites BELOW!....U pick one and use it for fast , friendly info and files, and many of these also have a LIVE chat area what U can get an IMMEDIATE response from reliable knowlegeable sources!...U will save yourself much time, especially if you are a newbie to this hobby!...and most all also will have the latest keys posted as well, and the keymaster, keyripper, key grabber utility files to download as well....and if plastic is your thing , some also have an area for that as well as FTA..Good Luck and enjoy this hobby!
Data Viewing Sequences
[link removed]
or get Keymaster 4.0 here free and NO registration is required...
[link removed]
NOW IS THE TIME TO USE THESE SITES FOR YOUR NEEDED NEW FILES..... New autoroll files are at all these sites..
