Dishnet key help
Username: Jryevols
Little rock, Arkansas USA
Post Number: 12
Good Evening..I truly need some help. When I manually dowload tonights keys the tv works fine for about five minutes , freezes and the keys on 00- automatically change the first two to 94. I put the right keys back in and it starts tv for another five minutes. Can anyone tell me how to fix?}
Username: Ustaad_hc
Post Number: 238
when you enter new keys make sure you save those keys first then exit.
Username: Jryevols
Post Number: 13
I do save them and then exit. I have been using this pansat for several months with no problem. I hit a wrong key the other night and had to reload everything. I don't understand why it freezes and then changes only the 00- first two keys
Username: Ustaad_hc
Post Number: 239
try the autoroll off.
Username: Jryevols
Post Number: 14
not to be stupid , but where is that found
Username: 1tina_chick
Post Number: 107
Satman - look in your main menu, you'll see autoroll options
I'm at 94 % Now !Upload
Post Number: 109
I Like the viewsat, any comments on this unit ? Upload
Username: Asharfi
Post Number: 678
Hey,
Viewsat is bringing out their new model (Viewsat VSPRO), but I don't know if it's available in Canada or not. Is that Viewsat VSPRO model out in the United States?
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 2851
http://www.skyhighelectronics.com/
Been out for awile,I have seen it selling cheaper tho, but this is vs canada repair and officall dealerhip.I haven't heard of it being cloned yet,so I think the cheaper priced dealer's should be ok,as far as clones go, but they can still burn you, be carefull who u buy from.
Post Number: 2852
http://www.skyhighelectronics.com/Viewsat-PRO-s/87.htm
sorry here's the pro link.
Post Number: 2853
Memo: I read somewere,there on the echo* sh*t list of dealers they want to take out. Take that for whatever thats worth.
