I reloaded new Bin 144 using loader 2.4 and everything loaded fine. When I connected back to the TV it just keeps turning on and off showing channel 490 "adult guard support" and would not let me even get to the menu. I thought may be things did not get loaded correctly so I reloaded the factory bin and then loaded version 143. Still the same problem. Please suggest remedies to this problem. Thanks
I had a simular problem like that and this is how i fixed it. 1. Load factory bin coolsat5000_100_20051007.stb 2. Do a factory reset 3. Then load latest COOLSAT5000_NORW_144_20070620 4. Do another factory reset then rescan and you should be watching TV again.
I did the same thing and still to carry out step 4. Sounds like it may be working but give me little more time to confirm the step 4. Thanks for your help.
