Need settings for Indian Channels
Username: Fortechhelp
Hai,
Can anyone post settings like LNB type,LNB local freq,Diseqc,skew etc for my fortech star life time ultra to get indian channels.I have 293 bin.
Thx
Username: Farooq1371
lnb circular,sat 61.5,transpoder go 7 or 8 transponder ahead of first one(12224)put it on 123...
Username: Nydas
Post Number: 2948
Echo 3 - 61.5W.
LNB type - Standard
Freq.: 11250
22KHz off
skew - usually -45
A blind scan for the first time, preferably with AutoTP and Autoroll off.
If some TPs do not come in after a Blind Scan, add specific TPs.
BIN should be 293T.
DiseqC setting in software should match the physical connection, i.e. 1/2 or 1/2/3/4.
