Help Needed
Username: Seanbhaskar
I have a Pansat 3500S, when I turn on my pansat it displayes the language screen..i go to english and press select and it goes to the menu....the chennel edit and parental control box are not usable, and when I click on installation and type in my password, the password does not work, and if I click exit then it goes back to the language select sreen. No new bin files were loaded since the last time I used this receiver. Please Help I am very frustruated with this as I have not done anything and now my sattelite is not working. Thanks.
Username: Nikk
Post Number: 1892
seanbhaskar...
Try this passwords...
1668
1010
Since you said parental control and channel edit are not usable, I assume you don't have any sat configured, you have to go through the installation menu, configure the sats and then do a blindscan to them...
Also check what bin the receiver has and get the latest one...
