Pansat clone
Username: Bcent
Los angeles, CA United States
hi there im using a pansat clone and all channels say descrambled ive aready tried factory reset and rescannig the channels again can smoe one please help me
Username: Lklives
Post Number: 9769
need MUCH more info...2 days ago there was a DN key change...and a reboot may help..
Username: Nikk
Post Number: 1786
If yor dish is aimed properly and when re-scanning you get all of the channels back then the only thing you need is to enter the new keys.
Go to menu and then to "system information" it will tell you which bin your receiver has, if you post it here we can help you a little bit more.
Username: Antiscums
Millburn, NJ
Post Number: 119
you better give LITTLE KID more info...before he asks you to go down on your knees and blow him... he's only 200 posts from platinum, hurry joey of CA
Username: Lklives
Post Number: 9776
IGNORE!
