Magnum TR V147 zip. is released
Username: Runnerguy
Pluto
Post Number: 146
Bin Version 147
Increased Stability
Team Reliable / Team Magnum
Magnum Users,
This been is the result of many hours of programming and testing. It is not perfect but an overwhelming majority of those that have tested it voted YES to release it. Please follow these instructions for the best results. A full Factory Default is NOT required on this file. However, by choosing the Default Configuration option, in the Factory Default menu, you will minimize potential for problems. The Default Configuration option simply resets some options in the menu and helps optimize the performance of 147. It does NOT change your Satellite Configuration and it does NOT delete your channels. It does reset your time setting so that will have to be reset.
New Features
Recall History - Located in Additional Options when saved in the ON postition it shows the last 10 channels when the recall button is pressed on the remote. When this option is saved in the OFF position the last channel only is recalled when the recall button is pressed.
Improvements
Menu/Message Labeling and Verbage Updated
Video Jitter Eliminated
Transponder Database Updated on 91 110 119
Picture Quality Enriched
MAPCall Processing Time Reduced
Once Again to our supporters we offer thanks and as always we welcome your comments.
ENJOY!!!!
Mikesmadd
