Megasat (pansat 2500 clone)
Username: Pooroldphil
Have new factory megasat installed new bin 290 and tried to put channel list on and nothing. Went back to factory settings and re-install bin and tried a blind scan. Just froze. what did I do wrong. I thought I did this before. Thanks
Username: On_the_beach
I am having the same problem~however I can load the channel list on the old bins, just not the new ones...
Username: Nikk
Post Number: 1321
For any 2500 clone you need the bin
X-85BL_DN_070203_290T_api from chancysand
Just get sure you are not downloading the bin file X-85BL_DN_070203_290_api that is for the original 2500
The "T" on the file means that is clone safe, if you have a clone and download the original bin it will kill your receiver and you will have to JTag.....
The 290T worked as the 290 is only for the true 2500's...Cheers Nikk!
Username: Skypatel
Post Number: 40
Hi Rod
Can you please post the excat website where you got the X-85BL_DN_070203_290T_api file for pansat 2500 clone model
Username: Yashmatharu
Brampton, Ont Canada
Post Number: 34
http://www.dssrookie.com/forums/
just need to register and it is free....
