2500A Sat Settings
Username: Runnerguy
Pluto
Post Number: 102
I am trying to scan 2500a and would like to know the sat settings for 110 and 119. Thank you for any help I might receive.
Username: Prfrmnj
Post Number: 1931
What type LNB's? What type dish? Where are you located? Switches??? All of this is needed....
Username: Runnerguy
Pluto
Post Number: 103
Dish Pro with dual LNB's for 110 and 119, North Central TX , Multi Switch. Sorry PRFRMNJ I should have know to include this info DAH!!. I used this box for a few months and just loaded a Program Guide from DSS Tester. Then bought a Magnum and learned how to get it set-up. I wanted to learn how to set-up the 2500A in learning effort as the 2500A is my back-up for now. Thank You very much for your help!!
Username: Prfrmnj
Post Number: 1932
If you are using an LNB like this one here is your setup:
LNB Type - DishPro
DISEcQ - 119 = 1 and 110 = 2
Everything else stays the same and DO NOT turn on the 22khz...
Also you should not be using any switches. You should run a line directly from the LNB to the receiver. The LNB has a built in switch.
Username: Runnerguy
Pluto
Post Number: 104
Thank You for your time and patience PRFRMNJ. Hopefully I can help people with this issue in the future.
