Keys
Username: Skypatel
Post Number: 24
Hi
Can someone please tell me how to enter new keys on PANSAT 2700 receiver for DISHNETWORK?
also which are the active keys for DISHNETWORK?
Please post step by step instruction on how to enter new keys for Dish Network.
Thanks
Username: Prfrmnj
Post Number: 1407
Patel - That question has been answered a few time. You need to do a little research and go to the thread already called "New keys"....
Username: Dude123
Post Number: 849
press 8282 on your remote that would take you to a menu, then select nagravision 2 and change keys under there. To change from 00 to 01 press volume button on the remote then change the keys.
Good Luck.
Nagra2 Keys
Dish Provider 0101: Last Updated (Jan08 8:36pm EST)
Key0: 7B A3 12 F7 A3 07 68 38 87 2D E3 D5 A1 09 51 11
Key1: C6 3E 92 9C 14 C0 41 41 05 7A FC 35 A4 4D 0E 8A (Active)
Bev Provider 0901: Last Updated (Jan18 12:00pm EST)
Key0: 76 3A 51 F9 0C 98 26 55 52 C6 BD BF C6 09 C7 C9
Key1: FB 31 EC 24 45 8E D5 EF 36 36 F8 1C C9 8F A5 71 (Active)
Username: Loikku
This key number is correct, but don't working bird 61.5
Help me!
Username: Kamalrose
Brampton, Ontario Canada
Post Number: 14
hi my dish is not working some channel is not working like zee t.v.-----sony t.v. and more----------its says scrambled or bad channel. i turn off the dish and turn on after some time but still same tell me what to do
Username: Hanz
Post Number: 170
Some channels might've gotten hit. Refer to the thread "DISH HAS BEEN HIT".
