2nd generation HD-DVD player from Toshiba
Username: Chico
Post Number: 76
w/ the introduction of Toshiba's 2nd gen. players that are fully 1080p, what happened to all the customers that bought the 1st gen. players. do they get a upgrade, a rebate, or are they crap out of luck. i know someone that bought one. did toshiba do this so simply they would be the first w/ hi-def disc to the market and that they fully knew less then a year that they would introduce a 1080p player.
Username: Tapeman
Post Number: 368
You can try to sell it on e-bay
I'm sure some-one can make good use for it
I guess blu-ray is the way to go
