Day night channels??
Username: Tsurat
Hi, I dont get any signal for some channels in the morning and by the evening i get all of them. Thought the signal is about 50%, but i get them quite clearly but that too only in the night? Any reasons??? your advise would be appreciated.
thanks
Username: Lklives
Post Number: 6484
I remember some threads about this long time ago here...suggest using search feature...they must be in the archives here...
With some its the opposite, better in day than nite, due to weather and moisture affecting cables and switches with colder nites...I guess it could work opposite as well...day thawing causing more moisture creating better in night time....U may want to "tweak" the alignment and consider changing cables and switch...check signal strenth in day versus night..TP's will have different strengths is normal..
Username: Pegg
Post Number: 34
It happened to me as well and then I found that dish was not properly alligned. Jus few degrees make a difference. Check the exact location, including elevation level.
Username: Playa_zihua
Post Number: 68
I have the same problem bit it is night when channels get bad LK i think has it right for me it is hot in day and cold in day
Username: Ars88
Bklyn, NY Rotti Pit
Post Number: 160
Username: Crazy_greek
Post Number: 288
Tas
The reason that you can receive all channels in the evening and not in the morning by a weak signal, is that there is less traffic in the air.This is your main reason.
Like Pegg said about you need to align your Dish.
Username: Donnie1973
Tennessee
Post Number: 493
traffic in the air??
