******** VIEWSAT PROBLEM ***********
Username: Pannu16
Post Number: 362
I uploaded new bin yesterday. Now what happens is my receiver shows on tv screen "SEARCHING FOR SIGNAL". I switch off my receiver from back and it works good for 40mins to 1 hour and then shows again searching for signals. then i have to do whole process of switching off and on. Wat can be wrong. My keys are autorolling anyways.
Username: Hawaiian_time
Hawaii
Post Number: 732
I don't know what could be the problem but try flashing your receiver with the factory bin and then load the new bin, see if that helps. That's always one of the last things to try. I myself haven't downloaded the new bin yet, just waiting to see what problems people encounter.
Username: Tapeman
Post Number: 98
These new bins got problems
If your autoroll works, turn autoroll off as soon as keys roll in
Good Luck
Username: Stormcat
Post Number: 12
pannu .. right on ... I have exactly the same problem with my VS and the new AR fix bin ...
Username: Pannu16
Post Number: 363
yeah i think thats the problem lots of ppl are facing!! So how wud we communicate this to viewsat coders. May b LK can help!!!
Username: Pannu16
Post Number: 364
anything new yet!!
Username: Pannu16
Post Number: 365
same thing happenin!!
Username: Pannu16
Post Number: 366
any answers!!
Username: Subzerocdn
Post Number: 39
totalF*A is the VS site
Username: Martinpraguer
Bohemia
Try to re-load with new .pgm file.
- do not switch Xtrme before clicking on to start downloding to receiver.
But most importantly TAKE YOUR TIME after loading before you switch it off !!!!!
new file name for: VSExtremeDBPSW-061122X.zip
It's working. Autoroll is working fine as well.
Username: Sstwired
I have a Viewsat Xteme VS2000, yesterday it froze up, I reloaded with factory bin ODS39000FA-V0268 20060913 XTREME.PGM On top of that I flashed DBPSW -- 061122X.PGM the latest bin. Did the Set-up reinstalled satellites, etc. Everything worked fine, then exactly the same problem as the first post, after an hour or so if I change sats, I lost the signal strength. It's "searching for a signal." Check the bars in the Installation menu and its lost strength. I have to reboot the receiver and it works fine again, for awhile then the same thing. In my case it appears that it is not cooperating with the Diseqc Switch, I was going to change it tomorrow now it appears that it is a Bin problem. Auto-roll works. Any suggestion?
Bohemia
Sorry, my is working 100%, but it is probably only since I am using only one dish/sat.
- I used to have all kind of strange problems back in September, e.g. when switching receiver off in the back, but I found the trick is to really let it sit for a short time after downloading .pgm file before switching it off and unlugging from computer. DO not rush it ! Since then it has been all honkydorry !
Cheers
Username: Pannu16
Post Number: 367
its nothin to do if ur using one sat dish, its just a bin problem, let me try doin it again!!
Some senior members please reply to this problem!!
Username: Schifty
Post Number: 29
I am having the same problem had to reboot about three times tonight,must be a problem with the new bin
Username: Pannu16
Post Number: 368
guys whoever is having problems, WHERE DID U DOWNLOAD UR BIN FROM!!
I got mine from al7bar.
i am gonna test something now. What i am gonna do is i am gonna do some testing and lests hope everything goes my way and if it does i'll let u by tomm. morning!!!
Username: Nahirpr
Puerto rico
somebody know the new bin for viewsat platnium?
Username: Pannu16
Post Number: 369
wrong thread elizabeth, anyways goto al7bar dot tk and u will get it there.
Username: Crippledwarcook
Post Number: 112
Elizabeth is nothing but a dumb fcuking broad...it's not like there is a 1250 different satellite sites out there with the new fixes...stupid fcuking women should not be allowed to touch these machines..they are way to fcuking stupid..ROTF
Username: Pannu16
Post Number: 371
easy buddy its her 1st post, cmon man easy~!!!
Username: Rampeij
Post Number: 13
Dont' mind that. Attention seekers. Probably some 12 year old on his mom's PC.
Username: Dankauff
everything you need to know to get your receiver working you can find here.
http://www.fsfta.com/
Bohemia
O.K.
It really looks like the file has a glitch, after few hours - signal loss. Soft switch off > hard switch off (in the back) > it's back to normal. We have to wait for update. But it's still better and faster (so far), then manually inputting the keys every day, specailly for poeple like me, that watch tv only for few hour.
Username: Lklives
Post Number: 5834
This was posted from a coder at dsscommunity..
there is a bug in this bin that screws with the signal
I didn't really notice till today as i been at work
when the box is on a channel for a period of time
an u chnage the channel apparantly the signal goes wacky
the powers that be have been informed of this
for some xtremes and platnium released files
So there should a new file comin soon
once i have it running i will share as always
Username: Pannu16
Post Number: 372
thanx LK!!
That was an update i was waiting for!!!
Username: Dimwitt
Post Number: 49
imagine the bashing if that was a BL bin!!!
keep up the good work mr.v
Username: Pannu16
Post Number: 373
any updates!!!
Username: Lklives
Post Number: 5838
At least VS fixes the problems...and doesn't keep pumping out same old BS bins with same old problems every week!...and then promise U more "FUTURE" improvements!
Username: Chuckk
You can turn off auto roll and it will not lose Quality and lock up. Then when the keys change turn it back on until it rolls. This has worked for about 5 hours now hope it helps.
Username: Pannu16
Post Number: 374
any new bins yet!!!
Username: Lklives
Post Number: 5850
be patient pannu!
Username: Pep
Post Number: 41
pannu,
please check ur disecq as i have encountered from viewsat new disecq but bad output if possible if you have other disecq change it or go to the other port.
Username: Lklives
Post Number: 5854
From dsscommunity reliable and knowlegeable source who himself creates new bins, pgms etc...this applies to ALL Viewsat 061122 bins..
for people having problems with DBPSW-061122X
with losing signal or freezing
this is what i was told an have done
been running my viewsat extreme all day
over 12 hours without problems
hit menu on remote
go to options and turn off auto TP
and turn off autoroll if u have picture
i have been switchin between dish 110-119-and bev 91 at different times an have
not had the signal issue or freezing that iwas getting day before
if the picture goes blank means key change turn autoroll back on
once keys roll then turn autoroll back off
jus a temp fix till they are done workin on the real fix
hope that helps
Username: Pannu16
Post Number: 375
thanx lk
Mike its a bin problem not a diseqc issue!!
Username: Lklives
Post Number: 5864
OK..heres the new Viewsat WORKING autoroll bin , with new opskey hex, loader, channel list,and all bugs fixed from previous bin yesterday!...all in 1 package...just posted and released minutes ago,an EXCLUSIVE ONLY at www.dsscommunity. com/forums! ...in Viewsat file area...yes U must register for FREE...ENJOY!
here's the direct link to this Viewsat Extreme package, remove the * in link...
[link removed]
Username: Lklives
Post Number: 5865
BTW..its ONLY for the Viewsat EXTREME!..not others..U can just use this new current opskey hex,loader and channel list from this zipped Extreme file in your other Viewsats..
Username: Pannu16
Post Number: 376
DEADMANZ PACKAGES ARE GREAT!!!!
