Bad Scramled chanel message and keys
Username: Jen_123
I installed the new bin two months ago and was regularly updating the keys.Autoroll and all other options except key are OFF (just like the One suggested) I started getting the "Bad Scramled chanel .." message just recently and not the "Picture upload %" message
The keys are correct, but I have this problem and can't find a solution.
Please help.
Username: Minn_rock
Post Number: 729
jen try to turn off your autoroll,go to auto option...let the keys code=ON...and the other 3 set it to =OFF
Username: Minn_rock
Post Number: 730
after u do all of that,check your keys again...
Username: Jen_123
I had the 3 set to OFF and keys code set to ON
I reset again just in case, changed the keys and still have this message "Scrambled or bad chanel"
I have a Pansat 2500A receiver.
This will drive me crazy - it was OK for so long and suddenly this scramled or bad chanel...
Any other suggestion --reloading the bin?
Username: Albino_midget
Post Number: 314
jen, if your current bin is 2 months old, i would update
www.future-fta.info
Username: Minn_rock
Post Number: 739
http://www.dssrookie.com/forums/
2500 clone safe 284t with tivo
Jen go head reload the new bin,and watch TV again..
Username: Horaceec
Long Island Bahamas
Post Number: 13
can someone tell me latest code for pansat 2500a november 17 2006?
