How to get *Canadian channels?
Username: Starlight
Post Number: 9
hi guys, is it possible to get the *Canadian chan with the 180T bin? all my FLU says is wait for picture;
thanks
Username: Fidarahman
Post Number: 60
Now you need to wait for the BIN file and not for the picture..may be couple hours away. And for Canadian channels u need your dish pointing to satellites 82W and 91W, and u get all the channels, if your BIN file is current and working.Hold you horses for a while
Username: Starlight
Post Number: 10
it worked last weeek for a short time with the 179T and then all was gone; I thought I must have done something wrong; I guess Bev and Charlie don't use the same bin and keys;
Username: Grimreeper
Post Number: 201
they same bin works for both but there use diff keys, turn autoroll off and enter the new keys manualy
Username: Starlight
Post Number: 11
which key to use and to which provider to enter it to?
Username: Dude123
Post Number: 266
Updated: Saturday, October 7 2006
Dishnet Keys, Provider 0101:
Key0: 0C FA 39 73 91 5F F5 54 E9 56 1C 42 8B 7A CA B2 (active)
Key1: 66 B9 F6 53 70 ED 2A 5B 31 D5 59 D2 9F 1C 52 63
Bev Keys, Provider 0901:
key0: C9 BB A9 83 ED AE 55 D6 62 DE 45 C1 EF 14 B5 D3 (active)
Key1: 5B 14 37 7E 7A 73 3C 38 C0 68 D5 A9 57 C2 13 D5
