Check your signal strength and also to make sure no TP give the error message while doing to blindscan, if it does mean u need to fix the direction of ur dish
It could be the weather because it never quits raining here in the north east so when it does quit i am going out and make some changes But on some channels like CNN i have 75% But thanks for the info i app . it Thanks
I had a similar problem yesterday. Couldn't get the signal, but it was easy to fix in the end. I just disconnected the power for a couple of minutes and took out the satellite wire from the reciever. Plugged everythign back in and it was fixed. It's a simple solution but hope it helps
Thanks for all of the info . What i did i went out in the rain and put a diff. dish up a couple inches bigger and realighed the dish and got everything back . Thanks i also have a 2700
my coolst5000 was working for 10min and then everything gone lost signal??????/ anyone know why??? how do i get it back..thank u..yes, i had the new bin 131???????
