Bronze Member Username: MrmeatPost Number: 45 Registered: Jul-06 | is there a difference between an unlocked 102 card at rev105, and a "virgin" 102 at rev 103... which will work in the cools@t? i had a 102rev105 in a dn reciever spoofed to rev109 and locked by myslef.. can i just unlock it and use it in my cools@t or is it "married" to the reciever.. help please.. tanks |
Gold Member Username: LklivesPost Number: 4187 Registered: Jan-06 | rev109 locked is no good.. |
Bronze Member Username: MrmeatPost Number: 48 Registered: Jul-06 | do locked cards work at all?? |
Silver Member Username: TotaldikguyPost Number: 130 Registered: Jul-06 | Yes, both will work. HOW? -The first one ("i had a 102rev105 in a dn receiver spoofed to rev109"), will work IF & only IF you saved the card unlock password, then unlock it again using same password, aux it with cs,DONE!Watch TV... If you did not save the password, there is NO way to unlock it, at this point of time. -whereas, the second one ("a virgin" 102 at rev 103...), just needs to be unlocked, aux it with CS, DONE! watch TV.... -"do locked cards work at all??" = NO! Enjoy... |
Gold Member Username: LklivesPost Number: 4188 Registered: Jan-06 | Sorry ...didn't see the word "spoofed"..thought it was at a rev109...also didn't read that U locked it... Locked cards can be unlocked with unlockers hardware.. |
Bronze Member Username: MrmeatPost Number: 49 Registered: Jul-06 | what about these red cards with the dn chip from the reciever that say they are rom102rev103... these any good? i see them for 140.. |
Bronze Member Username: MrmeatPost Number: 50 Registered: Jul-06 | and if i don't have the password anymore couldn't i still unlock it.. cuz even though i locked it, u said locked cards don't work.. mine works so i guess its not realllly locked.. couldn't it just be unlocked like other locked cards before rev109 |
Bronze Member Username: MrmeatPost Number: 51 Registered: Jul-06 | and by the way, i've heard only x2 card readers could be read by the cools@t and not the clone card readers, but i have a clone card reader and where it connects doesn't fit perfect but if you push it in hard enough it works, atleast from the cools@t menu it reads it as there. |
Silver Member Username: Albino_midgetPost Number: 110 Registered: Jul-06 | have fun, its all about the learning |
Gold Member Username: LklivesPost Number: 4192 Registered: Jan-06 | yes Co*olsat requires the X2 card reader ($35 at www.globalwholesalers.biz) for ROM 102 or Rom 103 cards..yellow card with red arrows thats are Rom 102/103 will work.. |
Silver Member Username: MorispastoraThunder bay, Ontario Canada Post Number: 196 Registered: Aug-06 | HERE ARE A BUNCH D**H YELLOW CARD WITH # ON THE BACK 1010001P04--288-12--????? Rom101 1010001P04--AA-05---108659--rom101 1010001P04--AA-05---?????--Rom101 1010001P04--AA-06---108659-Rom101 1010001P04--AA-06----?????-Rom101 1020001P07--AA-07---115434-Rom102 1020001P07--AA-07---??????-Rom102 1020001P07--AA-06---115434-Rom102 1030001P07--AA-06--120229--Rom103 1030001P06--SW-03-127697--Rom103 SW-02-127843-RomS01 SW-04-132037-RomS02 288-01--Rom2 288-02--Rom3 288-03--Rom10 288-04--Rom3 288-05--Rom 288-06--Rom3 288-07--Rom3 288-08--Rom3 288-09--Rom10 288-11--Rom10 325-01--Rom3 A2012--Rom3 A2013--Rom10 AA-01--Rom3 AA-02--Rom3 AA-03--Rom10 DN03-Rom10 DA-03--Rom10 Canadians Provider Blue Cards. EX-04--Rom102 EX-07Rom S01 A D**SH logo with a 500 inside a little square at this time I believe they are no Hac******ble.similar to the B**v S01. Rom's11 had the TV con the d**h500 in it.. |
Silver Member Username: TotaldikguyPost Number: 132 Registered: Jul-06 | mark anthony , Q: rom102rev103... these any good? A: YES, make sure it is not looped (kind fishy for $140) Q: if i don't have the password anymore couldn't i still unlock it... A: If it is lower than Rev 108 (using unlocker) Q: cuz even though i locked it, u said locked cards don't work.. mine works so i guess its not realllly locked.. A: Yes, it is LOCKED! That's why it's working. Card has to be locked to work (called stream lock or factory lock). A locked card needs to be unlocked before you can program/write/AUX it. Once programmed, it will then be locked again. Q: couldn't it just be unlocked like other locked cards before rev109 A: It can be unlocked, if it is before 109. REV 103 to 105 would be easy, without looping the card (but NOT a guarantee). The rest, you will need extensive reading, or you may loop it. Why extensive? Factors to consider, Rev#, type of unlocker, what script to use, Script configuration, Pot (potentiometer) ohm's setting, Dip switch setting, Voltage (sometimes), glitching timing and etc. Q: Is one setting/config, better than the other to a specific REV# or blah, blah blah? A: THIS IS TESTING. Your neighbor could be lucky, but that was your neighbor. Q: ADVISE? A: You have the dough? Why not! Reminder, a lot of pirates are selling their golds on the net, which I wouldn't trust. It's either you get rust or you get nothing, after you give them your silver $. ALL SALES R FINAL! |
Silver Member Username: MorispastoraThunder bay, Ontario Canada Post Number: 197 Registered: Aug-06 | I don't posted the # cards for selling it, that is information, because some people doesn't know what kind of ROM they sell/buy, |
Silver Member Username: TotaldikguyPost Number: 133 Registered: Jul-06 | Girls Gone Wild! And so with this forum site. Don't need to explain... It's been a pleasure (for the most part). My Last Post, TDG |
