I am attempting to load Dido's latest channel list to my VS Extreme. I am able to run Channel Master and it seems to be taking to the unit although when I load it up it appears to have wiped all the channels out. I am on the right COM port etc and had no problems with my old FLU. Wondering if there is a trick or something I am missing.
I actually loading the non-dishpro list although I doubt that has anything to do with it?
I tried the blind scan a couple of times and it appears that all the channels have come back. Only reason I wanted to try the list was for channels that were not being picked up with the blind scan. But, apparently, I did 2 blind scans and all the channels are back..
NOW >> NOW>> YOU two..... Minn you go to that coner over there >>>>>>>>>>>>>>>>>>>>>> davidvandiesel you can go back into ya mamma ....someone should of slapped her silly when she gave birth to ya .
