Temp Fix Pansat 3500sd
Username: Johnner
Miami, Florida
Post Number: 445
If you have a working 102 card you can use your Pansat 3500sd with this file:
http://www.dssrookie.com/forums/attachment.php?attachmentid=52353&d=1154782496
This file is not from Blacklist and is NOT an official
file. I do not know who/what/where/why (history) on this file so proceed with caution.
I have it working on my Pansat3500sd but I do not have a 102 to test it.
Username: Smarcus76
Post Number: 161
i dont think that works.. did you actually load all the channels??
Username: Hardrockstriker
Post Number: 400
I think that's a scam. I have heard of a few people trying the bin, but could not get it to work. Also, there are never any instuctions to be found on how to use it. And the kicker is that someone is selling manuals with the instructions for about $6 on ebay.
Hmmmm.....
Username: John_c
Post Number: 8
anything that is posted on rookie is usually tested if it passes for the mod's approval it will make its way to the status report
http://www.dssrookie.c0m/forums/satellite-and-industry-news/dtv-dish-fta-status- report-77311.html#post524558
Username: Pirate_pete
Post Number: 375
Pansat is totally committed to a cardless fix,I would be cautious, look for confermed working reports from reliable sources first.If it isn't posted at bl site it must have been a private fix /scam.
Username: Jmill1948
Chester, Va Usa
Post Number: 840
yes be very careful........
Username: Johnner
Miami, Florida
Post Number: 456
I have it running on my 3500sd with no harm done what so ever and when you insert a card on it a Message comes on basically saying that it trying to read a 102 card but since I do not have one I have not try it in its entirety.
