Bronze Member Username: SaturationPost Number: 40 Registered: Jun-06 | Ok the soccer game starts in 20 min. I have 2 dishes one points to 110 and the other to 119. First of all can I watch the fotball game on BEV? Second how do I turn my 110 dish to get BEV? Do I need new keys? What should I set the LNB to? It's currently at 10500? What's this rom 102 story? I have a ViewSat 2000 Extreme, no cards what so ever... |
Bronze Member Username: New07ftaPost Number: 56 Registered: Apr-06 | go to GOAL TV on 110 or 119 its free |
Bronze Member Username: SaturationPost Number: 42 Registered: Jun-06 | I just get something called GolTV? That what you mean? They only seems to send some old uefa cup stuff.. |
Silver Member Username: JohnnerMiami, Florida Post Number: 319 Registered: Nov-05 | 20 min; more than sufficient time to read. |
Silver Member Username: Leafs_fan_4_evaToronto, Ontario Canada Post Number: 173 Registered: Jun-06 | aren't all the channel's gone on 110 & 119?? |
Bronze Member Username: TadonDover, NJ Usa Post Number: 91 Registered: May-06 | ".. Ok the soccer game starts in 20 min. I have 2 dishes one points to 110 and the other to 119. First of all can I watch the fotball game on BEV? Second how do I turn my 110 dish to get BEV? Do I need new keys? ..." use 1 dish (110 or 119) look for 91 . Turn your dish to left side (standing behint your dish) about 5-10 degree & til up about 5 degree (I just guess . It is depending on where you are). Then adjust around that you will get signal of SAt. 91 . you need other key: D1 15 OC 8E 66 82 D9 80 90 A9 20 20 37 07 87 06 0C B7 0A F9 50 75 F3 5B 31 EC 79 97 5C D7 CE 1A ** turn off autoroll before input key # Hope this help |
Gold Member Username: EvadelparaisoPuerto Rico Post Number: 1371 Registered: May-06 | http://www.kusat.com/go.php?path=/install/look.php http://www.lyn***gsat.com/nimiq1.html remove *** |
Bronze Member Username: SaturationPost Number: 43 Registered: Jun-06 | Thanks a lot bui le...I turned the dish back and forth but never got any signal...time was running out so I headed for the nearest pub...nice game I will try to pick it up til next game. |
Bronze Member Username: TadonDover, NJ Usa Post Number: 92 Registered: May-06 | Sorry Ben, the number I gave. It wasnt a real number (I just guessed ) you can play with increase: to left & til up (based on 119 or 110 for sure). |
New member Username: LamparMontreal Post Number: 2 Registered: Jul-06 | I have the same problem to move from Echo3 (1.5)to Nimiq 2 (82). Changed to dish location, but then scanning to channels get all from Echo 8 (110). Please help me? What I'm doing wrong? |
