COOLTEC
Username: Naren3001
Post Number: 15
DOES ANYONE HAVE A CLUE FOR COOLTEC 4000?
Username: Lklives
Post Number: 3287
They have NOT made a new bin in 7 months...they are basically dead!...people just keep updating the keys..
try [link removed]
Username: Hotdagobabe
Post Number: 31
ok guys, the bin file 3122 is awesome, LOL except the EPG IS LAME, it will not update although the machine will record from epg now with this fix, it will not update epg, it will not show the bar showing it is updating, it does appear to be updating epg but it is not,, it is stuck, the epg only allows viewing of about an hour and a half, sometimes not even that,
how do i edit pvr files copied from 6000 to pc and convert to dvd, are these mpeg4?
