So by doing autoroll all the channels will work, 10 bucks
Username: Legend_killer
Post Number: 17
it was 20 but now i'm saying 10.
So by doing autoroll like blind scan and all that my receiver will haev all the channels except ppv right and i dont need to install the bin?
so can you tell me exact key and what do do with downloading a bin.
Username: Cosmic_ray
Toronto, Ontario CANADA
Post Number: 43
For BIN PANSAT 2700A
http://www.pansatusa.com/download.htm
Username: Lklives
Post Number: 3157
U need to upload the latest bin released yesterday/today for your particular specifib make/model FTA receiver, and put autoroll ON....then U will get ALL the channels INCLUDING PPV's!..No need for new keys, thats what autoroll does...
Obviously U haven't read anything and think this is Plug N Play...ITS NOT!..U must have LNB's on roof dish aimed correctly, correct FTA hardware and switches and correct receiver settings and scans already done first!
Username: Main420
Post Number: 42
good one LK :-)
Post Number: 18
The problem is i dont have a wire.
I heard that I need to do a blind scan turn auto rool off and enter some keys and that's it.
Username: Lklives
Post Number: 3160
GO AWAY...U ARE WASTING EVERYONE'S TIME...U MUST HAVE A CABLE BECAUSE U MUST UPLOAD A NEW BIN...U HEARD ALL WRONG!...AND THE CORRECT CABLE TOO AND READ FOR ABOUT 20 HOURS...THEN COME BACK..
Username: Viet004
Post Number: 9
YOU need to dl new bin and everythig is working, you can read the other 20 bucks that u post, the direction are in there...
Post Number: 19
OK, sorry.
So when will all start working again without the bins?
Username: Doubletrouble
Nc
COULD SOMEONE PLEASE TELL ME WHAT BIN TO DOWNLOAD FOR A ARIZA 700 WITH ROLLOVER AND WHERE I CAN GET IT I WOULD REALLY APPERCIATE THE HELP THANKS IM NEW AT THIS
Username: Viet004
Post Number: 14
no one known, maybe tomorrow, heheheh also maybe forever...
Username: Ttf
LK, Have Pansat 3500s (not a clone) so it says. I loaded 252 bin works for 2 hours all programs then locks up green light have to Jtag. Note: the new ECM says "that this unit may be a clone plaese contact your supplier" any suggestion ????????????????????????????
