Satcruiser receiver HELP ME PLS!!
Username: Pannu16
Please help me with my satcruiser receiver, its not working with any keys, it went out on 24 may, it has two line key 00 and key 01. I tried all the keys by splitting them but still its no working, wat shud i do, i literaslly tried all keys, please help me guys!!
Username: Califirnia
You may consider input the Key manually.
Look around on this forum you will find all the steps.
For the key, download the Keymaster or Key ripper software, you can get the current key instantly by running the software.
Key is the same for all machine, no matter what brand is it.
Good Luck.
Username: The_wank_artist
Post Number: 505
Take the keys listed as active and enter them into lines 00 and 01.
If you have two 00 lines, and two 01 lines, take both active keys and split them into 16's, then enter them both in 00 and 01.
