Pansat with C-Band
Username: Johnner
Miami, Florida
Post Number: 127
I was wondering if is possible to use Pansat with C-Band;
I did some reading and ended more confuse that how I started. I found a site with a similar receiver that needs an adapter in order to work with it.
I personally don't know if is even possible.
I would really appreciate any information on the matter.
Thanks.
Username: Johnner
Miami, Florida
Post Number: 129
Please Help!
Username: Evadelparaiso
Puerto Rico
Post Number: 184
http://www.global-cm.net/PAN2500SETUP.html
Username: Johnner
Miami, Florida
Post Number: 130
WOW! I've got a lot of reading to do...
lol
Thanks beautiful!
Username: Tdti1
Post Number: 23
It is very easy to slave a dvb receiver to a older analog ird or 4dtv receiver, take a look here:
http://www.dmsiusa.com/add_a_receiver.htm
If you only have C-band then of course you only split the C-band coax, though if you do not have c/ku It is well worth the upgrade, also if you do not have a 4dtv yet, it is a great investment.
Make sure you get the right splitters not to damage anything, your 4dtv or analog receiver will be the master, so you will change polarity with it, so you will need to scan H polarity, change the channel to scan V polarity.
Great places to get what you need:
http://www.rpssat.com
http://www.dvbmaster.com/
http://www.kusat.com/
They are all local for me, and are great to deal with.
Big dish is still the best system out there.
Username: Johnner
Miami, Florida
Post Number: 132
Thanks for all the help!
