Pansat 3500 Loss of Signal
Username: Conti
Post Number: 51
I have a pansat 3500SD that was working fine until I had an installer put another dish (148).
The 148 hooks into a DP Plus, that has 110 & 119, and I have 1 cable running to the Pansat.
I am able to scan in channels. I can watch a channel for a few minutes. Then loss of sognal and a change in the keys.
I have set default keys, but they seem to roll over.
When the roll over happens, I cannot get signal again until I switch off the box from the back.
I am lost, please help
Username: Conti
Post Number: 52
I decided to flash my box using the null modem.
I first flashed in the pansat factory bin using Loader 3.40, and was successful.
I then tried flashing bin 145 using blacklist loader 3.42, but failed. I could not get bin 145 flased using the blacklist loader.
What could be the problem ?
How do I remedy this issue?
