How to reflash a nonworking Pansat 2500a receiver
Username: Evadelparaiso
Puerto Rico
Post Number: 107
1. Swtich 2500a unit off in back.
2. Open the Blacklist Updater v1.4
3. Click the button that says "BOOT"
4. Load Boot60.bin in "SELECT BIN" window
4. Turn on back switch
5. On the third light - - - start the download ("WRITE BIN") and let it finish.
6. Turn off pansat backswitch
7. Turn pansat back on
8. Now you should see Knightrider lights - - - - over and over. This is normal.
9. Load the Pansat 2500A_040730_224_api(N).bin in Blacklist Updater v1.4
10 Click the button that says "BIN"
11. Click "WRITE BIN"... let it complete. The reciever will reboot when done.
12 Turn unit off and on again with back switch. Let the pansat boot up all the way.
13 In the Blacklist Updater, click the button that says "BIN"
14 Load the X-85BL_050128_243_api(N).bin in the Blacklist Updater ("SELECT BIN")
15 Write the 243 bin and let the receiver boot up by itself.
16 Now you are done... just load a good channel list or rescan and watch TV again.
Puerto Rico
Post Number: 108
This is the step for you follow, do you need find the new program update. Example one new Bin and Boot loader.
Puerto Rico
Post Number: 115
Pansat 2500A
Flashing the Receiver.
1. Connect Flash cable from receiver serial port to PC serial port.
2. Run File 2300_2500_1500 Downloader .
3. Select Com port 1 or 2.
4. Select Baud Rate 115200.
5. Enter STB Model key:global.
6. Click on Bin and Browse for file Blacklist_PK0_09-30-04_X-8500_040916_235_api-F. or the latest autoroll file for the pansat X-85BL_050315_245_api(N). Use the 85BL for the 2500 or the 87BL for the 2700.
7. Click on Download.
8. Receiver should display percent of completion.
9. Wait until Download is Complete.
10. It must say Download Complete
This completes the receiver flash program.
Loading the Guide
2. Run File gtools 1.85.
3. Click on File.
4. Click on Open.
5. Select the guide file Dish 119&110 for Dish Network Legacy LNB's, DishPro 119 & 110 for Dish Pro LNB or 5-16-04 5 tp list gtd mod 2-Favorits+ for a total channel guide list for Dish Network Legacy LNB's.
6. The Guide should appear with channels.
7. Select Options.
8. Select STV Setting
9. Select The Second Option
10. Select Tools.
11. Select STB Connect.
12. Select Com1.
13. Select 115200 Baud.
14. Click Download.
15. The receiver should display the percentage of download.
16. Wait until the download is Complete.
17. It must say Download Complete.
This Completes the Guide Download
Receiver Settings
1. Power on Receiver
2. Press Menu
3. Select Installation
4. Select Antenna Setup
5. Scroll up or down to desired Satellite.
6. Press volume control to select. A check should appear.
7. Press OK to change settings.
a. LNB Type Standard
b. Frequency 11250 for Dish Network
c. 22Khz OFF
d. If you are using a Dish Pro LNB then the 110 satellite should be DISEqC 2 & the 119 satellite should be the DISEcQ 2. If you have individual LNB's & a DISEqC swith then you would set 1 for the 1st LNB 2 for 2nd LNB, Etc. Switch # must match.
e. Skew 0
f. Transponder Varies
g. Positioner Disable
h. Sat Scan All
8. Use exit button to go back to select another satellite.
9. After setting up all LNB's press exit.
10. Exit Antenna Install.
16. Turn receiver off with rear switch.
17. Turn receiver on after 10 seconds.
18. Click here to Set in the keys at this point. Watch TV and Enjoy.
Set-up of a Pansat 2500A FTA Receiver for Nagravision Satellites (Optional Reading)
This document will help you through the necessary steps to get your system up and running. It is based on experience as well as information gathered from a variety of internet sites. You should note that using an FTA receiver to descramble broadcasts is illegal and you do so at your own risk.
The 2500A will not have a program guide, which is about the only drawback. There is a bit of a guide with BEV, giving the show name and information using the EPG button and 'i' button for info.
Username: Lunabulldog
Ms Diaz you seem to know your staff!!!!
