Pansat Clones
Username: Johnner
Post Number: 117
Here is how to program a Pansat 2500a (clone)
First download the bin file 273t
http://www.clickspin.com/FTA_Down/X-85BL_060318_273_au_api(N).bin
You can use this loader:
http://www.clickspin.com/FTA_Down/2500A-Downloader.exe
Upload the file and do a blind scan on the SAT's.
Username: Jmontana1
Post Number: 17
i am back everyone!
Username: Dafee99
Post Number: 26
that bin is not for clones.. people can fry their clone with that bin. even though there is no guaranteed clone safe bin, 273t should be clone safe and is working. 273t was fixed from the original, 273, to work with clones. again 273 is not 273t. it might work, but that how people kill their receivers...
Username: Johnner
Post Number: 118
I have it running in 5 clones with no problem!
2 Fortec Star
1Fortec Ultra
1Lava 3200 DVB
and 1 Pansatclone 25000
Username: Dafee99
Post Number: 27
The 273t should say X-85CS_060318_273T_GC_DN_BEV_RTN_TVE_4sec_api(N).. If you notice BL is the original maker, CS is the one that makes it adaptable for clones..
but as they say, if its working... personally, I would not risk it.
Username: Johnner
Post Number: 119
You are right it is better not to risk it with the 273>> so here is the 273t:
http://stillironmen.tripod.com/sitebuildercontent/sitebuilderfiles/x-85cs_060318 _273t_gc_dn_bev_rtn_tve_4sec_api_n__133.zip
Username: Lklives
Post Number: 2485
where do U keep coming up with these no name sites that are non reputable and couldbe FCC owened and or virus spreading?...why not use the REPUTABLE sites that have been around and are well known for years...
I wouldn't go to thes sites U post!
