What in the lords name?
Username: Dirtysouth
Lehigh Acres, FL USA
okay, So I HAVE been reading and trying to soak all this in! I WILL NOT ask for the new codes for the 2500A as I see them in a million places! Poor LK! anyway, I believe after reading I see that i have the newest bin 273t! I am missing my Local Naples channels, all ppv's and some kids channels! MY SATELLITEman has me set up on 0101 01 If I try to use 0101 00 i get zip! Does this mean that I have a software problem! When he comes he just wham bam plugs it into the laptop and 5 seconds later he is gone! never explains squat! I dont know if I need to wait for all my channels to go down and the new codes (not listed yet) to come out or if there is a simple fix that does not need a computer! I saw some stuff anout renaming the sat? Maybe that is something I need to do? Bare with me, In time I will learn ALL THIS but FOR NOW i just LEARNED HOW TO DO A DESTRUCTIVE RECOVERY ON MY DESKTOP!
Username: Dafee99
go to menu-- parental control---
second bin "0000" "set default keys" exit out to channels--- wait seconds to a few minutes for picture...that might do it
Right now I am running a blind scan! Winging it here! i will try that next!
THX!
Username: Lklives
Post Number: 2260
Naples...Bonita springs...Fort Myers etc locals like WINK and them are spotbeamed on the 110 satellite... TP-transponder 4...spot#1....so U need to scan 110 and TP 4
U must check out www.lyngsat.com and http://ekb.dbstalk.com/dishlist.htm
WZVN TV 26 (ABC) Naples WZVN 9215 4s1 110° E*10 . . Local - Ft. Myers
WINK TV 11 (CBS) WINK 9216 4s1 110° E*10 . . Local - Ft. Myers
WBBH TV 20 (NBC) WBBH 9217 4s1 110° E*10 . . Local - Ft. Myers
WFTX TV 36 (Fox) - Cape Coral WFTX 9218 4s1 110° E*10 . . Local - Ft. Myers
WTVK TV 46 (WB to be CW) Naples WTVK 9219 4s1 110° E*10 . . Local - Ft. Myers
WEVU CA 4 (UPN) WEVU 9220 4s1 110° E*10 Local - Ft. Myers
WGCU TV 30 (PBS) Naples WGCU 9221 4s1 110° E*10 . . Local - Ft. Myers
WRXY TV 49 (CTN) Tice WRXY 9222 4s1 110° E*10 . . Local - Ft. Myers
and quit burning the woods and houses down there..I was at the little Indian casino there today (Ft Myers- Immokolee-Lehigh area).....nice day to ride the bike earlier..
Username: Lklives
Post Number: 2261
BTW...those are on channels 9215-9222, if U don't understand!
Okay, so now I know that I need to run a scan! lol Which scan? I have NO idea about scanning! I can go to
SAT Scan
TP Scan
Network Scan
Blind Scan
And I have options of scanning Sats:
Blank Chans
Echo 7@119
Sat-3
Echo 6,8 @110
Once I click on one of these Sats I have a list of 1-28. I chose Sat Scan 110 and clicked 1-28 and scanned each!
Then i went to TP scan on 110 and clicked each of those. I know thats not correct! I guess do not know how to do a TP4 Scan!
Username: Lklives
Post Number: 2270
U scan the satellites that U have LNB's on your roof aimed at....sounds like U don't have a LNB on the dish aimed at the 110 satellite....if U did, when U did the 110 scan, then TP 4 scan, U would have received those locals..
1 LNB on roof dish receives 1 satellite
2 LNBs....gets 2 sats
3 LNB's... gets 3 sats
4 LNB's ...receives 4 sats
That is where U start when doingbthis hobby...first put a dish on roof and aim the LNB's towrad the satellitesmU want...then make sure U are aimed correctly...U should get the FREE unscambled channels from each satellite U are CORRECTLY aimed at, BEFORE U add bins etc on the receiver..if U don't know how, there are a milliom satellite TV shopis inyour area that will come and align the disgh for U for a fee..suggest using the 110 and 119 satelites..
Username: Tinfish
Cant find TNT on DN. Can anyone please post SAT/TP? Thanks
Username: The_wank_artist
Post Number: 112
TNT tp 8 on 119 E*7.
Post Number: 113
Find it tin?
TNT tp8 on 119 e*7
12326
Username: Tinfish
Tyler: Thanks for the info. Did a TP scan and didnt find. I'm now doing a satellite scan on echo 7hopefully i will find it.
Username: Tinfish
Post Number: 7
tp scan on 12326 found 0 programs. So did a blind scan on E7 and now tried again. Still no luck. I dont know how a satellite scan would then help but i'm trying it anyway
Post Number: 115
It might have moved today then. Both the lists I've been using have it on 8 / 12326. But both list have not been updated today. Last update was the 3rd.
http://ekb.dbstalk.c0m/dishlist.htm
you'll have to remove the 0's in c0m to view.
Username: Tinfish
Post Number: 9
Tyler..no luck.
Username: Tinfish
Post Number: 11
Im not finding any channels on TP 8. ESPN and TNT Besides channels moving around could any other setting be wrong?
Post Number: 123
the channels from 12326 have moved to another tp.
It's there somewhere if you've done a sat scan.
It will not be in the same location in your channel lineup as it was before. Look for it at the end of your channel list. I'd scan the sat myself to find it but my wifes watching ER.
Username: Tinfish
Post Number: 12
Tyler..plz dont waste your time scanning. actually with bin 273T on my ultra I dont think I have E 119 on the list. Even tho it shows as E 7, in the detailed info it says 110. how can i add a satellite if it is not already on the list ? Dumb questions. Sorry
Post Number: 125
You'd need two LNB's on your dish, one to pickup 110 and the other for 119.
do you have two?
And do you have a channel list built for both 110 and 119 on your system?
If no to the lnbs, get one.
If no to the channel list, go to a REAL fta site and download one that includes both the 110 and 119 info.
And by REAL I mean not that crazy kids site.
Username: Tinfish
Post Number: 13
I have two LNBs. Here's something else i found. All this is fascinating! on my satellite list there's a sat showing as SAT-46. When i do info on channels on it it says E 119. However the LNB type is Universal. When I select standard on it, the signal falls to 0. The TPs are on frequencies in the 10000s. Wow. I need to learn about channel lists. Let me do some reading. If you have any clue on the SAT-46 let me know. Thanks again.
Username: Tinfish
Post Number: 14
Tyler. Thanks for all your help. Found them all on SAT-46. Blind scan found 56 transponders got al the channels i was looking for. Again thanks. People like you and LK are really helpful
Username: Gsmax
I did a sat scan and got everything back on newest numbers, but somehow the channels are not grouped together like they used to be (ex. all hbo, sho, max were all together. Now they are all over. Tried to do a channel sort, but all I see is alphabetical, tp, sat, parental control sorts. Any idea how to get them back to where they were. I got used to the hbo's being at 300 and up, the ppv's at 501 and up...Any suggestions. Thanks
Username: Lklives
Post Number: 2327
Works on all Pansat Series. Might take a few try's to get it to work.
1. Delete ALL channels on ird.
2. Go into SAT Edit and rename your Dish 110 to ECHO 110 and rename Dish 119 to ECHO 119. (the space between ECHO and 110 is important!)
3. do a BLIND scan on each sat, ECHO 110 & ECHO 119. (Takes At least 10 min per sat)
4. When complete, push SAT button on remote, you will now have a choice you have not previously had "ECHOSTAR PACKAGE"
5. Select ECHOSTAR PACKAGE and select any channel. This will convert EPG Button to ECHOSTAR PACKAGE and your epg will match match D**H Network channels. ( provided you are pointed at 110 and 119)
After doing this, you will see there is no need to load a channel list and epg works fast on most channels, slow to come up on others.
Username: Tinfish
Post Number: 15
I'm trying to use LKs instructions above but my satellite list has echo 6/8 and echo 1/2 on my Fortec when I look at the info both echo 6/8 and echo 1/2 show up as Echostar 110 W. How do I decide which one to include to Echostar Package?
