Switch question
Username: Gagansingh1
hello all you genius people. i have a question. i want to install fta. i have alreay my dishes installed, with the previous boxes (with card). now i want to install fta. do i also need to change the swtich or the previous one will work.
thanks in advance
Username: The_wank_artist
Post Number: 96
A switch runs $15 at the most.
Try the one you have, if it doesn't work, go buy one that is compatible with your FTA receiver.
